Slingbox SOLO Motherboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,078
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The purpose of this guide is to show the steps necessary to remove the casing of the Slingbox and replace the motherboard.
Tools
    1. Slingbox SOLO Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
      Ask FixBot
    2. Slingbox SOLO Motherboard Replacement: step 2, image 1 of 3 Slingbox SOLO Motherboard Replacement: step 2, image 2 of 3 Slingbox SOLO Motherboard Replacement: step 2, image 3 of 3
      • The Slingbox has four black 5mm screws, one on each corner of the case.
      • Remove the four black 5mm screws using the PH1 screwdriver.
      • Gently pull and separate the two case covers.
      Ask FixBot
    3. Slingbox SOLO Motherboard Replacement: step 3, image 1 of 3 Slingbox SOLO Motherboard Replacement: step 3, image 2 of 3 Slingbox SOLO Motherboard Replacement: step 3, image 3 of 3
      • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
      • Remove the five silver screws on the motherboard using the PH1 screwdriver.
      • Gently slide and separate the motherboard from the base.
      Ask FixBot
Nitin Muralidhar
222 Reputation
2 Guides authored
IUPUI, Team 2-2, Harley SU 2016 Member of IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,078
