Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vacuum Will Not Turn On
The vacuum does not turn on or show any indication of powering on.
Faulty Battery Terminals
Make sure wires are inserted into the battery all the way repair or replace damaged wires. Follow the replacement guide for a step by step instructions.
Faulty Charging Port
Check connections on the charging port and check inside to see if the connection inside the port are damaged. Make sure terminals are properly connected. Follow the replacement guide for a step by step instructions.
Vacuum Not Picking Up
The vacuum pass over the debris and does not pick it up.
Bad Front Belt/Front motor
Make sure the front belt is attached to the motor and brush roller, check power connections to the front motor. Make sure belt is attached to the motor and brush roller. Follow the replacement guide for a step by step instructions for the Front motor, and follow the replacement guide for a step by step instructions for Front belt.
Clogged Filter
Make sure filter is properly installed if not remove and reinstall correctly. Make sure filter is not full of debris. Follow the replacement guide for a step by step instructions.
Main Suction Motor Not Working
Check connection on the motor and make sure the impeller is not jammed. Follow the replacement guide for a step by step instructions.
Ben Dzugen
383 Reputation
3 Guides authored
USF Tampa, Team 16-2, Blackwell Spring 2017 Member of USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Members
72 Guides authored
30 Comments
When the vacuum is turned on is the brush roll supposed to spin because mine doesn't
Mary - Reply Share
The brush roll has its own motor. You have to buy a replacement. It costs about half the cost of the vacuum itself! I just bought one… and now the actual vacuum has completely died on me. This thing has been nothing but money and hassle!
i8yourmom4lunch - Reply Share
After a few seconds of being on it turns itself off and flashes between the hardfloor and carpet settings before turning off completely! It’s done this with both batteries and is just new so have no idea what is wrong with it?
Claire - Reply Share
Did you find an answer Claire, mine does the exact same!
Linda - Reply Share
Mine is also doing the same! have you found an answer yet?
amarler1 - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 39
All Time: 36,612
