Shark Cordless Pet Perfect Front Motor Replacement
    1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: step 1, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: step 1, image 2 of 2
      • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
      Ask FixBot
    2. Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 1 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 2 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 3 of 3
      • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
      Ask FixBot
    3. Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 1 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 2 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 3 of 3
      • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
      Ask FixBot
    4. Shark Cordless Pet Perfect Front Motor  Replacement: step 4, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement: step 4, image 2 of 2
      • Remove the belt from the motor mount, and then replace with a new belt.
      Ask FixBot
    1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: step 5, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: step 5, image 2 of 2
      • Remove the solder from both motor terminals.
      Ask FixBot
3 other people completed this guide.
Ashley Calkins
560 Reputation
3 Guides authored
USF Tampa, Team 16-2, Blackwell Spring 2017 Member of USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Members
72 Guides authored
2 Guide Comments
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - Reply Share
Where can I obtain the new motor with the plastic gear?
F V - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 3,186
