Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Samsung ST76 won't turn on
Your camera does not turn on.
Battery is drained
Make sure the battery is fully charged.
Make sure the battery is inserted correctly into camera.
After the battery is fully charged and placed in the camera, close the battery compartment and turn the camera on. If this does not work, consider replacing the battery with a new one.
The zoom lens is stuck
Your camera's zoom lens does not extend or retract properly.
Debris in lens
Examine the lens for dirt or dust particles that may be restricting movement. Blow into the crevices to attempt to remove.
Camera needs restarting
Turn the camera completely off, and then back on again. Rebooting your camera may fix your stuck lens. If this does not work, there may be a motherboard issue. See how to replace your motherboard here.
The flash button is stuck
Your flash button is unresponsive.
Flash button was pushed improperly
Press the flash button and hold it down firmly.
Debris in crevices
Examine the button crevices for dirt or dust particles that may be affecting function. Blow or shake out the possible debris, then press the button firmly again. If this does not work, the flash may need to be replaced. See how to replace your flash here.
The lens cover is damaged
Your camera's visibility is impaired by an unclear or cracked lens.
Lens is dirty
If there appears to be dirt on the lens, gently wipe it away with a lens cleaning cloth.
Lens is cracked
If your camera lens is cracked, it will limit the functionality. It is highly recommended that you replace you camera lens if this occurs.
The screen won't work
Your screen is unreadable, unresponsive, or cracked.
Screen is cracked
If your camera screen is cracked, it will limit visibility and functionality. You can see how to replace your screen here.
Motherboard is malfunctioning
If your camera screen is not showing the correct display, try restarting it by turning the camera all the way off and then back on again. If this does not work, there may be a problem with the motherboard. See how to replace it here.
Author
with
Jessica Bain
408 Reputation
2 Guides authored
Marist, Team 1-6, Laflen Spring 2015 Member of Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 Members
48 Guides authored
2 Comments
Hello, my lense won't come out and it says "zoom lens did not operate normally"
Nomafu Mtamo - Reply Share
Hi I have an issue with an Samsung ST77 I hope I can fix this but my battery thingy I put it in the cam I try to turn it on but it has no response and if I try charging it, it just blinks a red light meaning a issue with the battery, I only got this camera as an untested cam
Yuta Okkotsu - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 54
All Time: 2,722
