Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
POWERbot Does Not Charge
Your POWERbot does not have power.
Emergency Switch
Check if the emergency switch is on. If the emergency switch is not on, turn it on.
Battery
First look at the charge indicator to see if the POWERbot needs to be charged. If the POWERbot is not charging, first check to make sure the charging station is firmly plugged into a power source. Confirm that the outlet is receiving power by using it to power another device. Make sure the charging pins on the docking station and the POWERbot are aligned correctly.
If the POWERbot fails to charge after following these steps, you may need to replace the battery.
POWERbot Fails to Return to Charging Station
Your POWERbot is unable to reach docking station.
POWERbot is Immobilized by an Obstacle
If your POWERbot is unable to reach the docking station, make sure the area around the charger is clear of obstacles. If it continues to not reach the docking station then you may need to manually charge the POWERbot. To manually charge, lift up the POWERbot and place it on the docking station. Make sure the charging pins on the docking station and the POWERbot are aligned correctly.
Power Failure
Check if there is a power failure or whether the power plug is securely plugged in. If there is a power failure, test the outlet the docking station is plugged into with another device to ensure the outlet has power. If the power plug is unplugged, plug it in to a known working outlet.
POWERbot Can't Connect to Wi-Fi
Your POWERbot isn't recognizing your Wi-Fi.
If your device is not connecting to the Wi-Fi, check your wireless router's setting status.
Try resetting your wireless network. Locate the power source plug on the Wi-Fi router and unplug it. Wait at least 30 seconds, then plug it back in. After resetting the router, try to reconnect your POWERbot to the Wi-Fi.
If the device still does not connect to the Wi-Fi, you may need to replace your POWERbot's wireless antennae.
POWERbot Shows an Error Code
Your POWERbot's display screen shows one of the following error codes: C 01, C 02, C 03, C 04, C 05, C 06, C 07, or C 11. Find the displayed error code below.
C 01
Foreign object is caught in the brush. Turn off the emergency switch, and remove the foreign object from the brush. After the foreign object is removed, turn the emergency switch back on.
C 02
Foreign object is caught in the left driving wheel. Turn off the emergency switch, and remove foreign object from the left driving wheel. After the foreign object is removed, turn the emergency switch back on.
C 03
Foreign object is caught in the right driving wheel. Turn off the emergency switch, and remove the foreign object from the right driving wheel. After the foreign object is removed, turn the emergency switch back on.
C 04
Foreign object is caught in the auto shutter tool. Turn off the product by pressing the emergency switch and remove the foreign object from the auto shutter tool. After the foreign object is removed, turn the emergency switch back on.
C 05
Bumper sensor needs to be checked. Turn off the emergency switch, and then turn it back on. Check if there is any foreign objects between the main body and the bumper. If there is a foreign object, pull the bumper slightly, and then remove the foreign object. After the foreign object is removed, turn the emergency switch back on.
C 06
Foreign object has accumulated on the obstacle sensor. Turn off the emergency switch, and with a soft cloth clean the front and rear sensor. After the front and rear sensor is clean, turn the emergency switch back on.
C 07
Foreign object has accumulated on the cliff sensor. Turn off the emergency switch, and with a soft cloth clean the cliff sensor. After the cliff sensor is clean, turn the emergency witch back on.
C 11
Main PCB needs to be checked. Turn off the device and restart it. If the problem persists then the battery may need to be replaced.
POWERbot's Suction is Weak
Your POWERbot is not properly vacuuming the areas it covers.
Increasing Noise
If the noise of your POWERbot significantly increases, turn off the emergency switch, and then empty the dustbin.
Filter Inspection Indicator
If the "Filter inspection indicator" is on, turn off the emergency switch, and clean the dustbin. When there is too much dust in the dustbin, suction power becomes weakened. Turn off the emergency switch and empty dustbin.
Intake Blocked
If the intake (bottom of the POWERbot) is blocked by a foreign object, turn off the emergency switch, and then remove the foreign object from the intake.
Author
with
Eric Anderson
465 Reputation
2 Guides authored
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Members
60 Guides authored
35 Comments
This network issue is stupid. I have 73 devices online in my smarthome. I cant just go reset everything and my router. I should have done my homework on the powerbot r7070 better. If id known they cant handle networks properly then i would never have bought it. I am very disappointed.
Anthony Lombardo - Reply Share
Same issue here! Super upset. It wont work on any of my network and rolls right over that “magnetic tape” barrier. Not to mention there are VERY few results for any troubleshooting searches on this thing…
Matt brown - Reply Share
I recently got my r7070 about a week ago. I set it to go clean when i heard something caught in the dust bin (piece of dog food). I emptied it out and unclogged some hair in the front. When i had it resume cleaning the vacuum only moved around with no suction. I tried going from the three power levels but nothing seemed to work. Any ideas what happened? It was working until i emptied the dust bin.
matthew henn - Reply Share
Did you ever figure out what was wrong mine is doing the same thing
Peyton G Stracener - Reply Share
My r 7070 was working great. Till it picked up ?. Mess.said something was caught in the roller. I cleaned the roller and put it back in…
Now it makes a noise like roller is hitting the bottom cover… what do I do?
tammy brunk - Reply Share
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 54
All Time: 25,658
