Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop is getting hot
Cooling Fan Is Clogged
If the cooling fan is clogged with dust, you can clean it out with a can of compressed air.
Cooling Fan is Bad, and Needs to be Replaced.
If the laptop is overheating the cooling fan may need to be replaced. To replace the cooling fan, use this guide.
Computer is running slow or freezing
RAM needs to be cleared
Sometimes you can fix this problem by resetting the ram. If the problem persists you will need to replace the ram.
RAM needs to be replaced
If the computer is still running slowly, you will need more RAM. Use this guide to replace the RAM.
Computer storage is full
Computer Has Too Many Junk Files, or Unused Files
If the computer is full on storage, you can delete files or programs that you don't use. To delete files, click on 'Start' at the bottom left of the screen. Then, click on 'My Computer'. Go through your files, and delete any files and program that you don't use, or don't need.
Hard Drive Needs to be Replaced
To replace the hard drive, use this guide.
Computer won't power on
Power is Not Plugged in
If the computer won't power on the battery may be dead. Try plugging the laptop into the charger, and plugging the charger into the wall. A charging light will come on to the left of the mouse pad.
Battery Needs to be Replaced
To replace the battery, use this guide.
Can’t connect to wi-fi
Wi-Fi is turned off
Check that your wi-fi has not been accidentally turned off. Press the fn key and the f9 key simultaneously.
Router is off
Ensure that your router has power and the wi-fi light is on. If the router light is on but wi-fi is still not working then call your service provider so they can troubleshoot the router.
Laptop is not connecting to 3G internet
SIM card needs to be replaced
If the computer is not connecting to the 3G network, the SIM card may be bad, and need to be replaced. Before you replace it, try removing the SIM card, and putting it back in. If that doesn't work, replace the SIM card with a new one. To replace the SIM card, use this guide.
Amir Afridi
626 Reputation
6 Guides authored
USF Tampa, Team 4-1, Passmore Fall 2016 Member of USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 617
