Samsung NP N310 HAA2US RAM Replacement
    1. Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 3 of 3
      • Make sure the laptop is powered off, and unplugged before removing the battery.
      • Slide the battery switch to the unlock symbol, and the battery will pop up.
      • Remove the battery.
      Ask FixBot
    1. Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 3 of 3
      • Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
      • Pull off the memory panel.
      Ask FixBot
    2. Samsung NP N310 HAA2US RAM Replacement: step 3, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement: step 3, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement: step 3, image 3 of 3
      • Pull the 2 latches holding the RAM in, away from the RAM stick, and the RAM will pop up.
      • Pull the RAM out of the slot, only touching the edges of the RAM stick
      Ask FixBot
Amir Afridi
626 Reputation
6 Guides authored
USF Tampa, Team 4-1, Passmore Fall 2016 Member of USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Members
72 Guides authored
1 Guide Comment
I checked out this guide today (11.2022) to upgrade the RAM in my N310 Windows XP laptop that I bought in the summer of 2009 : ) a whooping 2 GB of DDR2 RAM installed to play old games on original hardware... yee haw!
Mick Germ - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 93
All Time: 810
