Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
White screen when netbook is powered up
When the netbook is turned on the screen is white.
Faulty Ribbon Cable
You will have to open the device and replace the ribbon cable.
Function Keys are not working
If a fn + another key combination is not working properly
Download and install Easy Display Manager/Easy Settings
Download and install Easy Display Manager/Easy Settings from the Samsung Download Center. See the Samsung troubleshooting here.
Audio Cracking and Sound Distortion
The audio crackles or has a high pitched sound when I play a music file.
Loose Headphone Jack
Make sure there is no hardware issue by listening to the music file via headphones. If the music sounds normal then there is a hardware issue.
Replace the speakers
You will have to open the device and replace the speakers.
Overheating Netbook
The netbook is making a lot of noise and is overheating. This can also cause the netbook to run very slow.
The air vent is clogged
You will have to open the device and clean the air vent.
The fan has stopped working
You will have to open the device and replace the fan. See the guide linked here.
The battery is overheating
You will have to replace the battery. See the guide linked here.
Netbook is not powering on
Netbook is not turning on when plugged into the wall.
Dead Battery
Charger not working
You will have to replace the charger or contact Samsung.
Brian Smith
405 Reputation
2 Guides authored
USF Tampa, Team 1-1, Sullivan Fall 2016 Member of USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Members
72 Guides authored
2 Comments
black screen keybord not work and usb not work to
joeborc79 - Reply Share
When i put power on, screen and keybord not work
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,546
