Samsung NP-NC10-KA02US Fan Replacement
    1. Samsung NP-NC10-KA02US Fan Replacement, Battery: step 1, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement, Battery: step 1, image 2 of 2
      • Locate the external battery on the bottom side of the device.
      • Locate the tab on the right side of the battery.
      • Shift the tab to the left.
      Ask FixBot
    2. Samsung NP-NC10-KA02US Fan Replacement: step 2, image 1 of 1
      • Locate the tab on the left side of the device's battery.
      • Push the left tab to the right.
      Ask FixBot
    3. Samsung NP-NC10-KA02US Fan Replacement: step 3, image 1 of 1
      • Pull the battery up from the device.
      Ask FixBot
    1. Samsung NP-NC10-KA02US Fan Replacement, Back Plate: step 4, image 1 of 1
      • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
      Ask FixBot
    2. Samsung NP-NC10-KA02US Fan Replacement: step 5, image 1 of 1
      • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
      Ask FixBot
    3. Samsung NP-NC10-KA02US Fan Replacement: step 6, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement: step 6, image 2 of 2
      • Using two plastic opening tools remove the back plate.
      • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
      • The back plate is now removed exposing all of the hardware components.
      Ask FixBot
    1. Samsung NP-NC10-KA02US Fan Replacement, Fan: step 7, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement, Fan: step 7, image 2 of 2
      • Remove the three screws holding the fan using a 3.9mm screwdriver.
      • All three screws need to be removed in order to continue on to next step.
      Ask FixBot
    2. Samsung NP-NC10-KA02US Fan Replacement: step 8, image 1 of 1
      • Unplug the wires connected to the fan using a plastic opening tool.
      Ask FixBot
    3. Samsung NP-NC10-KA02US Fan Replacement: step 9, image 1 of 1
      • You are now able to carefully detach the fan from the base.
      Ask FixBot
2 other people completed this guide.
JHOAN USECHE
372 Reputation
2 Guides authored
USF Tampa, Team 1-1, Sullivan Fall 2016 Member of USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 114
All Time: 1,286
