If your troubleshooting problems are not addressed here, please see the user device manual for additional solutions.
Your Gear freezes or has fatal errors
Your Gear freezes and does not respond.
Too many apps running
If your Gear is freezing but the touch screen is responsive, close all applications. Place two fingers on the screen until the Open Apps screen appears, then swipe either right or left to close an app.
Still not responding after closing all running apps
If your Gear is frozen and unresponsive, press and hold the Power button for at least 7 seconds to reboot.
After closing all running apps and rebooting it
If neither of the above options work, you can reset your device. Before resetting your device, make sure to back-up copies of any important data that may be stored on the Gear.
On the Home screen, go to Settings → Reset Gear → OK.
Gear won’t turn on
Your Gear will not boot.
Dead battery
If your Gear is not turning on, it is possible that it may have a drained or dead battery. This is often the case if you have not used your device recently, for the battery will slowly drain over time. Plug it into the charger to see if the Gear will charge.
Bad internal battery connections
If it is still not turning on, you will need to check the connections inside the device and possibly replace the whole battery altogether. A guide to replace the battery can be found here: Samsung Gear 2 Battery Replacement.
Gear’s touch screen works improperly or lags
Your Gear’s touch screen responds slowly.
Unclean hands
Make sure that you are only using clean, dry hands while operating the device. The use of objects, wet hands, or dirty hands may result in malfunction.
Software out-of-date
If the software on the Gear is out of date, it may malfunction or work slowly. Restart the Gear and check that its software is fully updated.
Bad protective cover
A protective cover for the screen may also cause malfunction. Try removing the cover and testing the gear's functionality.
Broken or scratched screen
A scratched or broken screen may cause the problem and must be replaced.
Another Bluetooth device cannot locate your Gear
Your Gear cannot be found by another device.
Devices too far from each other
Verify that your Gear and the other Bluetooth Device are within the Bluetooth connection range of 10 meters. The distance of the connection varies upon the environment and surroundings of the device. Objects such as walls interfere with connectivity.
Check that the Bluetooth wireless feature is activated on your Gear. To access the Bluetooth settings from the Clock screen:
  • 1. Swipe right to access. Settings → Bluetooth.
  • 2. Toggle the Bluetooth option to turn it on, and it will automatically be visible to other devices until it connects to your mobile device.
  • 3. Place a check mark next to the name of a device if you want your Gear to remain visible to that device. To hide your Gear from other devices, leave them unchecked.
If Bluetooth is still not working
Reset your Gear and try connecting to the Bluetooth device again.
If the above tips above do not solve the problem, contact a Samsung Service Centre.
Bluetooth disconnects from the device or the connection is not established
Your Gear disconnects with the other device or a connection is never established.
Bluetooth is not on
Interference
Obstructions, such as walls or any electrical equipment, between the devices may result in a weakened connection.
Old version of Gear Manager Application
Make sure that the latest version of the Gear Manager application is installed and updated on the mobile device.
Not within range
Ensure that your Gear and the other device are within the Bluetooth connection range of 10 meters. The distance may very depending on the environment of the devices are used in.
Error messages appear when launching the camera
Low battery
Check if your Gear has enough charge in order to use the camera. If the battery has low energy, charge the battery.
Not enough memory
Your Gear must have sufficient available memory in order to operate the camera. Free some memory by deleting files or unwanted photos from your Gear.
If camera is still not working
Restart the Gear. If the camera application is still having problems, contact a Samsung Service Centre or look into replacing the camera here: Samsung Gear 2 Camera Replacement Guide.
Author
with
Devin Mast
637 Reputation
1 Guide authored
Cal Poly, Team 13-27, Maness Spring 2014 Member of Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Members
72 Guides authored
65 Comments
Mene jb Samsung gear2 ko reset kiye uske baad connect ho hi nhi raha hai or na Bluetooth on hai
Anand Prasad - Reply Share
I updated my gear 2 to Tizen which was great - I then switched phones to the 6 edge plus and my gear would not connect - I then reset the gear 2 and now it is stuck in a connection mode that says go to Samsung gear manager and connect - Samsung gear manager recognises the watch but says it cannot communicate? any ideas
Richard yhap - Reply Share
Mine is the same, did you get an answer to this?
hope4merh - Reply Share
Exactly same issue. Reset watch, off/on bluetooth, unistalled/installed app. Nothing.
Sasha Kealalio - Reply Share
My Gear 2 Neo will now no longer connect with my S5. It's not a phone bluetooth issue as the phone connects with my other devices. It's not a watch bluetooth issue as once I reset the watch it connected but hung up waiting for Gear Manager to respond, which it never does. I've reinstalled Gear on the phone. Any other suggestions?
George Wilkinson - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 76
All Time: 129,759
