Up to 20% off select tools
Samsung Gear 2 Camera Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
115
All Time:
4,461
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
  • Spudger
    4.9
  • Tweezers
  • T5 Torx Screwdriver
    4.9
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a broken camera in a Samsung Gear 2.
    1. Samsung Gear 2 Camera Replacement, Front half and Back half: step 1, image 1 of 2 Samsung Gear 2 Camera Replacement, Front half and Back half: step 1, image 2 of 2
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      Ask FixBot
    2. Samsung Gear 2 Camera Replacement: step 2, image 1 of 1
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      Ask FixBot
    3. Samsung Gear 2 Camera Replacement: step 3, image 1 of 3 Samsung Gear 2 Camera Replacement: step 3, image 2 of 3 Samsung Gear 2 Camera Replacement: step 3, image 3 of 3
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      Ask FixBot
    1. Samsung Gear 2 Camera Replacement, Camera: step 4, image 1 of 2 Samsung Gear 2 Camera Replacement, Camera: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the rectangular metal connector that attaches the camera to the Gear.
      • Use tweezers to gently lift and detach the metal plate of the connector.
      • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
      Ask FixBot
    2. Samsung Gear 2 Camera Replacement: step 5, image 1 of 1
      • Use tweezers to carefully lift the camera from its slot out of the case.
      Ask FixBot
2 other people completed this guide.
Author
with
Allison Michel
513 Reputation
3 Guides authored
Cal Poly, Team 13-27, Maness Spring 2014 Member of Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Members
72 Guides authored
1 Guide Comment
Hey cool! Were can i buy the camara?
jorge - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 115
All Time: 4,461
