Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Phone Fails to Charge
You have trouble getting your phone to charge while it is plugged in
The Outlet or Charging Cable is Faulty
Ensure the outlet works properly by plugging another device known to work into the socket. If the outlet works, use the charging cable on another Android device if possible to see if it charges.
The Firmware Crashed
The firmware may have determined that the battery was at full capacity, not allowing the battery to charge. To reset the firmware, open the back panel of the phone and remove the battery. Once removed, press and hold the power button for one minute to drain the extra battery power. Then, install the battery back in, place the back cover on, try turning it on, and try charging it again. This resets the firmware and allows for the battery to be charged again.
The Charging Port is Dirty
Ensure that the charging cable is fitting properly within the charging port. The charging port accumulates dust and debris; clean the port out using pressurized air or dry cotton swabs. The pins within the charging port may be misaligned with the charging cable, move them around with a toothpick to make them straight again.
The Battery is Faulty
If these other solutions do not work, the battery may be faulty. Consider replacing the battery and if the problem still persists, seek help from a technician or take it back to the store for assistance.
For more information follow this link:
https://thedroidguy.com/2019/01/fix-sams...
The Screen is Frozen or Unresponsive
The phone does not respond to touch, display remains the same
The Phone is Running Out of Storage Space
One of the most common symptoms of a phone running out of storage is a frozen or unresponsive screen. This is because every service that your phone runs will create temporary files to help it run smoothly. When there is not enough storage space for these services to load their necessary files. This will force close apps that are already running resulting in performance issues.
The Third Party Apps are Faulty
A third party application downloaded from the PlayStore or manually installed is causing the problem. Reboot your phone into safe mode, this will not fix the problem but it will confirm if the problem is coming from a third party app. In safe mode all third party apps will be temporarily disabled and the device should work normally. If you find the app that is causing the problem, reset it by clearing the data and cache. If this does not work you should uninstall the app.
The Firmware Has Problems
All other procedures have failed to fix the phone, so it must be a firmware problem. Before you reset your phone to its original settings make sure you backup any important files, they will be deleted and unable to be restored otherwise. Also be sure to disable the Factory Reset Protection in order to avoid getting locked out of your phone.
The Screen is Cracked
If the screen on your device is cracked try replacing it by following this guide.
The Camera Displays Error Message
You try to take a picture on the camera app and it displays an error message or closes immediately.
The Camera App is Crashing
Ensure the camera app is not experiencing a simple application crash. Tap the Apps icon from any Home screen to go the Settings. In the Applications tab, tap the Application manager and select the Camera App. Go into the storage setting and hit Clear data, confirm, then Clear the cache. If the application was undergoing a simple crash, the camera will work.
The Settings or Configurations Are Incorrect
Reset your phone to factory settings in order to rule out that the error message was due to incorrect settings. This will delete all existing files and all possible corrupt data. Make sure to backup all personal and important files prior to the reset.
Check and make sure the firmware has not crashed. The firmware could The firmware may have problems and could close out applications. To reset the firmware, open the back panel of the phone and remove the battery. Once removed, press and hold the power button for one minute to drain the extra battery power. Then, install the battery back in, place the back cover on, and turn the phone on. This resets the firmware and allows for the camera app to work again if the firmware had crashed.
The Audio Output from Headphones or Speakers is Distorted Or Broken
The audio coming from the phone has a crackling sound or is not playing any sounds.
The Audio Settings Need to Be Changed
The problem could be the volume setting is not set to a level you can hear. Check the system settings (labeled “Settings” in the list of apps). Try adjusting the audio levels in the setting or use the side volume buttons to make sure it is on.
If that does not work, go into the system settings (labeled “Settings”) and check if there is an issue with the output settings. Check in the list of settings and if there is an option “Restore Default Settings” use that and then test audio again.
The Speaker is Faulty or Broken
The problem could be the phone speaker does not work. Try replacing the phone speaker or have a professional technician look at the phone.
The Headphone Jack is Dirty
The issue may be the headphone jack has lint inside if problem only happens when using headphones with a wire. Look at the headphone jack at the bottom of the phone and check to see if there is any lint or residue build up sitting inside the port. Turn off the phone. Use a toothpick or similar sized tool and stick it into the port and scrape off any build up.
Take the edge of a tissue and stuff it into the port. Then twist the tissue around a few times to wipe away any leftover residue. Remove the tissue. Power on the phone and plug headphones into headphone jack and test if sound is still distorted.
The Audio Port is Faulty or Broken
The problem could be with the audio port. Try replacing the audio jack.
https://www.androidauthority.com/headpho...
The Phone Won’t Turn On
The screen stays black when you try to turn the phone on.
The Phone May Be Out of Charge
The phone does not turn on because the battery is dead. Attempt to charge your phone to see if it is the battery preventing the phone from turning on. Allow the phone to charge up to an hour. If the phone still does not turn on then you may have a variety of issues. One possible solution is to check if your charger is working properly. Try using another charger. If the phone still does not turn on then there may be something wrong with the phone. One cause of phones not charging is that debris sometimes gets stuck in the charging port which prevents the device from charging. Check if there is any debris in the charging port, if there is, take it out carefully without making any damage.
The Phone was Dropped and The Hardware Was Damaged
If the phone was dropped recently it is possible that the hardware inside the phone was damaged. To test whether hardware was damaged or if it is simply a software issue, try charging the phone for up to an hour and see what happens. Sometimes the battery completely runs out which is the reason for the phone not turning on. If the phone still does not turn on after charging for an hour try removing any external storage media. After removing the external media attempt to turn on the phone by holding the power button. If that doesn’t work, then the most likely cause of the phone not turning on is that internal hardware was damaged. The only solution to this is to repair your phone or have it repaired by a professional
The Phone Was Dropped in Water
If the phone was dropped in water take the battery, SIM card, and SD card out to prevent those from being damaged. One solution to getting water out of your phone is by placing it in a bowl of rice. Leave the phone upright in the bowl of rice for a couple days before you attempt turning it on again. After that, put the battery, SIM card, and SD card back in the phone and attempt to turn it on. If the phone still does not turn on try to charge it. However, make sure that the phone is not heating up. If the phone still does not turn on then you will have to get the damaged components replaced.
https://thedroidguy.com/2019/01/things-n...
Isabel Gamez
62 Reputation
0 Guides authored
Cal Poly, Team S19-G2, White Winter 2019 Member of Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Members
60 Guides authored
4 Comments
phone is running slow. What do I need to do?
Sharon Dickenson - Reply Share
Phone is running slow. What do I need to do?
Phone keeps coming on and off all the time
florine adams - Reply Share
I have a Samsung Galaxy j3 emerge not staying on. It's coming on and off on it's own
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 42
All Time: 4,280
