Samsung Galaxy J3 Emerge Screen Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
73
All Time:
3,777
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Screen Replacement guide for a Samsung Galaxy J3 Emerge Model SM-J327P. To heat the adhesive up that holds the screen on the phone, use a hairdryer. The screen might need replacing if the display is unresponsive or if the phone won't turn on. The screen can be replaced if the original cracks.
Tools
    1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: step 1, image 1 of 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: step 1, image 2 of 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: step 1, image 3 of 3
      • Heat up the edges of the screen with a hair dryer.
      • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
      • Work the iFixit Opening Tools around the whole screen to break the glue.
      Ask FixBot
    2. Samsung Galaxy J3 Emerge Screen Replacement: step 2, image 1 of 2 Samsung Galaxy J3 Emerge Screen Replacement: step 2, image 2 of 2
      • Lift the screen up from the bottom.
      • The screen could crack when lifting it up.
      • Pry the gray cover open.
      Ask FixBot
    3. Samsung Galaxy J3 Emerge Screen Replacement: step 3, image 1 of 2 Samsung Galaxy J3 Emerge Screen Replacement: step 3, image 2 of 2
      • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
      Ask FixBot
7 other people completed this guide.
PJ Yebisu
286 Reputation
1 Guide authored
Cal Poly, Team S19-G2, White Winter 2019 Member of Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Members
60 Guides authored
2 Guide Comments
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - Reply Share
Gostei da aula parabens muito gratificante.
athoscost - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 73
All Time: 3,777
