Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Headset has become uncomfortable
After wearing the headset, It has become uncomfortable the cushions are starting to peel away and wear out or have become dirty.
Cushion are Dirty
Your cushions are dirty but still useable, you will need to remove the ear cushions and clean them. To clean leather ear pads, use a warm, damp cloth and soap to wipe down any spots. For cloth ear pads, apply a damp cloth and soap, or wash the ear pads in a washing machine.
Cushion have worn down or ripped
Your cushions are ripped or worn down, you will need to get new ones and replace them.
Sound is low or not coming through at all
There is no audio coming through or it is very faint.
Volume slider might be down
If the sound coming through the speaker is very low or not transmitting at all use the slider on the headset and raise it to the maximum volume.
The headset might not be plugged in all the way
Make sure the cable is fully connected to the jack and not slightly loose otherwise it might affect the audio.
System Settings
Make sure whatever system you have the headset plugged in to does not have the audio lowered or turned off and if it is simply raise it to a comfortable volume.
Defective Speaker
The speaker within the headset is no longer working properly and you will need to open the headset and replace the speaker.
Microphone not picking up audio
When trying to speak into the microphone, no audio is being recorded.
Microphone is not plugged in correctly
Try re-plugging the headset into the correct jack to see if it was incorrectly plugged in.
The Microphone is muted
Make sure the mute button the microphone isn’t turned on. if it is turn off the mute button.
Defective Microphone
Your microphone may be defective and not be able to pick up any audio at all. In that case, you would need to order a replacement microphone and replace the microphone.
Headband will no longer adjust properly
When taking off the headset, dropping the headset resulted in the headband breaking and it is now unwearable.
The Headband is Cracked or Damaged
After your headset might of taken a fall, or the headset has taken damage in anyway, the headband might break or crack and become uncomfortable and won't fit on your head properly. you will need to replace it.
Unable to Mute
When toggling the button to stop recording your voice, your voice still records anyway.
Defective Mute Button
Your mute button may be defective and not able to toggle properly. In that case, you may need to take your headset apart and replace the button.
Headset Does Not Connect to Any Devices.
When trying to connect the headset to a phone or laptop, the bluetooth will not connect.
The Headset Isn't Charged
Your battery might be low or even dead. If the batteries are low, the signal strength may be very weak and unable to connect to your devices. You are going to want to charge your headset by plugging the charging cable into the charging port.
Faulty USB Port
Your wireless dongle might not be fully functioning due to the USB port that you plugged it into. Try plugging the dongle into a different USB port.
Faulty Wireless Dongle
Your wireless dongle may be defective and not able to toggle properly. In that case, you may need to order a replacement dongle.
The Bluetooth Module might be faulty
The Bluetooth Module within the headset itself could be defective, and wont allow your headset to connect to any device. you could try restarting the Bluetooth adapter on your device within the settings.
Short Battery Life
After charging the headset, the headset dies after a short amount of time.
The Battery wont charge
If the headset will not charge try changing the cable, if the new cable still wont charge the headset check to see if the charging port needs to be cleaned out, try blowing into it or using a q-tip to clean out any gunk.
The Battery might be damaged
Your battery might be corroded, or damaged and it will need to be replaced. In this case, you will need to take the headset apart.
Author
with
Cameron Pacheco
101 Reputation
0 Guides authored
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 Members
48 Guides authored
15 Comments
The color thing that is blue just keeps on blinking and it won’t connect to my device even tho I’m at half percent
ha al - Reply Share
I have the same issue
Colin LeMaire - Reply Share
And Me this headset is donkey $@$*
James Lock - Reply Share
My Bluetooth just doesn't work at all
meighan_meighan - Reply Share
the headvand didn't vreak, vut the headphone part (the part that actually goes on your ears and plays sound through them) just detatched entirely. what should I do?
noah - Reply Share
Past 24 Hours: 15
Past 7 Days: 82
Past 30 Days: 339
All Time: 41,898
