Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet won't turn on
Nothing happens after the power button is pressed.
Tablet shuts down after disconnecting charging cable
If the tablet is charging when the cable is connected, and the tablet shuts down after unplugging it, then the most likely problem is that the battery is dead. Look at the solution for fixing dead battery issues.
Dead battery
If tablet turns off after charging cable is disconnected, or if tablet does not turn on at all, then it may be time to replace the battery. Follow this battery replacement guide for instructions. Then test to see if your tablet is working by turning it on.
Audio is distorted
The speakers are distorted, and the noise crackles. The sound does not work at all.
Speakers are dirty
Dirt, debris, or other grime might be stuck in the speakers or speaker housing. Try to gently use a cloth and wipe away anything on the outside, blow or used compressed air, and very lightly go over the speaker. This will help clear any grime out of the speakers and then test the sound again. If they are still not working, then you should try replacing the speakers.
Speakers are faulty
If cleaning the speakers doesn't work, the speakers may be faulty or broken. For instructions on replacing the speakers, follow this guide.
Poor WiFi connectivity
WiFi signal is weak, slow, and/or spotty.
Radio interference from other devices
Other electronic devices, such as microwaves, may create interfering radio frequencies. Try switch to the 5GHz WiFi band. (Will show up as a separate access point in list of wireless networks)
Router is obstructed
Having the wireless router far away, in a different room or in a cabinet can degrade signal strength. If possible move the router to a more central and open location. Another option is to install a wireless repeater in an open area to boost signal strength.
Author
with
Omar
261 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 803
