PlayStation won’t turn on
First, ensure that the power cord is properly connected both at the back of the device and at the wall socket. If the problem persists, try powering the PlayStation from another power outlet. If the device still does not turn on, you may have a faulty power cord or may need to replace the Power Supply.
PlayStation suddenly resets itself during play
This may be the result of a faulty power cord or a loose power socket. (The power socket is the connection at the back of the device that receives the power cord). Repairing the power socket is possible, but may require soldering. Since other components can be damaged during soldering, we recommend replacing the entire Power Supply.
No image on TV
Make sure the video cables are connected properly to your television and ensure that the correct video input and channel are selected on your TV. If the TV still shows no image, the Logic Board may be the problem and should be replaced.
Game does not load, skips, or freezes
Dirty or damaged game disc
Try playing a different game. If a different game plays normally, the first disc is likely dirty, scratched, or has label damage. If the disc is dirty, clean it with a soft lint-free cloth and try the game again. If there are scratches, they can likely repaired with a CD scratch repair kit. (CD scratch repair kits are sold by most electronic stores and are relatively inexpensive). If there is damage on the label side of the disc, it cannot be repaired.
Dirty lens
Dust may have accumulated on the lens, making it difficult for proper reading of the game disc. If the lens needs to be cleaned, use a cotton swab and a proper lens cleaning solution that can be found in any electronic store.
Broken spindle hub
The spindle hub is used to hold the game disc firmly to the spindle assembly. If the spindle hub breaks, the game disc will slip as it spins and the laser will not be able to properly read the game disc. The spindle hub can be replaced, but exchanging the entire Optical Drive will be a much easier fix.
Faulty optical drive
Game loading errors, skipping, and freezing often result from a faulty optical drive. Some symptoms include:
  • No spinning or abnormal spinning of the game disc
  • Loud tracking noises
  • Failure of the laser to move along its track
If your device encounters any of these problems, you should replace the Optical Drive
Controller not responding or is not found
What type of controller are you using?
There are three different controllers Sony has created for the PlayStation. The first did not have the dual analog feature (the two joysticks). It was not until the second controller was released that the dual analog feature was incorporated. The third controller is the dual shock controller that provides a force feedback (vibrates to stimulate game play).
Many times a controller that is not read or is non-responsive is a result of playing a game that is not compatible with the dual analog or the dual shock controller. So before blaming the controller port, verify that the game being played supports the controller you are using.
Also, controllers that are sold by outside companies (not Sony made) may encounter problems because many of them incorporate new features and multiple functions.
Faulty controller port
If the proper controller is being used and it is still not responsive or if the message "controller not found" is given, then the problem is most likely a faulty Controller Port and replacing it will be necessary.
Memory card not read
Try using the memory card in another console. If the other console is also not able to read the memory card, then the memory card is most likely the problem. If the other console does read the memory card, then the Controller Port is the problem and will need to be replaced.
Author
with
mdarling
2,068 Reputation
0 Guides authored
Cal Poly, Team 5-2, Regan Fall 2009 Member of Cal Poly, Team 5-2, Regan Fall 2009
CPSU-REGAN-F09S5G2
5 Members
60 Guides authored
43 Comments
I have a Playstation one mini and it powers on and the game comes up but the picture on the screen almost looks as if it's on the wrong channel but it's not. Can't find any information on youtube or anywhere about this to see if it can be fixed. does anyone know how to fix a ps1 mini with a garbled picture screen.
Mike Williams - Reply Share
Sometimes a tv doesnt support the low resolution of the ps1 so its best to get a cheap upscaler but first you should try another tv first
mohamadfire2 - Reply Share
I have a PlayStation on and when I start it up, a grey screen with two boxes come up. One of them is clearly some kind o settings for my memory card and the other is some sort of music maker, early GarageBand thing. I can't get out of it and it comes up whether there is a disk in there or not or if there is a memory card in there or not. What do I do?
Liam Wright - Reply Share
By music maker, I assume you're talking about the "box" that says "CD Player", correct? For future reference, that's just, as the name says, used for listening to CDs, should you feel like listening to one on your PlayStation. But, I digress, the screen as a whole pops up when the console's lid is open, when the console thinks a disc isn't placed in it, or when it detects a CD. Are you sure the lid is closed completely? My Playstation's lid stays popped up a bit, even when it clicks closed; I have to put something like a book on top of it to weigh it down so that it's fully shut. Perhaps your discs are a bit dirty and/or scratched instead and they can't be properly read? Otherwise, like it already says on this page, maybe your spindle hub is damaged, or it could be something wrong with the console's laser; either issue can cause a PlayStation to be unable to read the disc correctly, resulting in that screen showing up whenever you use the system.
Chaise - Reply Share
I have a Playstation and When I start it up with out a disc in it there is a blue arrow pointing to the memory card but when I put the memory card in the slots provided , the blue arrow goes away and is unresponsive . Do you know what I can do?
corrinehoover - Reply Share
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 221
All Time: 83,849
