Up to 20% off select tools
PlayStation Controller Ports Replacement
Views: 32K
View statistics:
Past 24 Hours:
10
Past 7 Days:
56
Past 30 Days:
273
All Time:
32,474
Comments: 12
5 comments on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your PlayStation is no longer registering controller input or recognizing memory cards, it may be time to replace the controller ports on the console. This guide will take you through the process of replacing this component, which includes the controller ports and the memory card slots in one assembly.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
    1. PlayStation Controller Ports Replacement, Open the Console: step 1, image 1 of 1
      • Before you begin, make sure the console is turned off and unplugged.
      • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
      Ask FixBot
    2. PlayStation Controller Ports Replacement: step 2, image 1 of 2 PlayStation Controller Ports Replacement: step 2, image 2 of 2
      • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
      Ask FixBot
    1. PlayStation Controller Ports Replacement, Remove the Controller Ports: step 3, image 1 of 1
      • Remove five Phillips #1 screws securing the metal shield to the controller ports:
      • Two 14 mm screws
      • Three 8 mm screws
      Ask FixBot
    2. PlayStation Controller Ports Replacement: step 4, image 1 of 2 PlayStation Controller Ports Replacement: step 4, image 2 of 2
      • Lift the metal shield straight up to remove it.
      Ask FixBot
    3. PlayStation Controller Ports Replacement: step 5, image 1 of 2 PlayStation Controller Ports Replacement: step 5, image 2 of 2
      • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
      Ask FixBot
    4. PlayStation Controller Ports Replacement: step 6, image 1 of 2 PlayStation Controller Ports Replacement: step 6, image 2 of 2
      • Lift the controller ports straight up and out of the bottom case.
      Ask FixBot
14 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
7 Guide Comments
I try replacing the controller and still wouldn't play memory cards.
redevil19 - Reply Share
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - Reply Share
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
I'm having a weird issue, it will read in second do
Port but not the first. Changed controller port and still having the same issue
michael wise - Reply Share
The problem on mine is where I can’t use memory card slot 1 but Slot 2 works and is what I use but I would like to used slot 1 and have more than just a single memory card for playing games on it.
Travirus - Reply Share
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 273
All Time: 32,474
