Overview
Before you get a replacement zipper, you need to know what size and pull type to get. While pull type is not critical, you can use the image below to select a preference. So long as the zipper is the right size and type, it will work fine.
Size
Plastic tooth zippers come in three sizes: 3VS, 4VS, and 5VS. To find your zipper size, turn the zipper over and look on the back of the slider. Another place to look for zipper size is on the bottom of the zipper box. Note that on the bottom of the zipper box the number for the size will be the same (i.e. 3, 4, 5) but the "VS" will be replaced with an "S" in some cases.
Plastic Tooth Zipper Size 3V
Plastic Tooth Zipper Size 4V
Plastic Tooth Zipper Size 5V
Pull Type
Lastly, you need to know your preference for pull type. Take a look at the image below and choose your preference.
Zipper Pull Types
Zipper Pull Types
1. Round rubber Vislon slider
2. Reversible coil pull (This pull is for reversible zippers only. Not sure? Check out our zipper identification page.) (These pulls come in different colors)
3. Bottom Vislon slider
4. Basic slider
5. Rounded top Vislon slider
6. Rubber slider
7. Rectangle slider (These pulls are for coil Zippers. Not sure? Check out our zipper identification page.)
8. Rubber slider
Author
with
Jake Devincenzi
119,666 Reputation
57 Guides authored
3 Comments
Price?
Slider #7
I need it for a plastic zipper.
mary_luz_r - Reply Share
I need,slider #7 for plastic zipper. Price?
Slider for plastic tooth zipper. Please?
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 96
All Time: 6,899
