Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Video Distortion
You have trouble seeing the video feed from the camera.
Smudges on the Lens
Take an eye glass cloth and clean the front camera lens to make the image clearer.
Bad Connection
Disconnect the drone from the FreeFlight Pro app, then close the FreeFlight Pro app and turn off the drone and turn it on again. Reconnect the Bluetooth.
Broken/Defective Camera
If your drone does not show a clear picture within the FreeFlight Pro app, the camera may be broken and needs to be replaced.
Drone will not connect to a smartphone or tablet
The drone will not connect to a smartphone or tablet via WiFi.
Reset needed or outdated firmware
To reset the drone press and hold the power button for 10 seconds. The LED will blink green and orange for a while, then green and the drone will shut down. If the drone's firmware has not been updated recently, an update can help solve your problem
Improper IP address
In your phone or tablet's WiFi setting of the device go into the details of the connection and ensure the IP address is 192.168.1.xxx   The "xxx" can vary from either a single digit to three digit number.
Improper WiFi connection
If already connected go into the WiFi setting of your device and select "Forget this network."  Restart your device and then go back and connect to the drone’s network. Then go into the FreeFlight Pro app and try connecting once again.
Battery does not charge
The battery does not charge or charge fully.
Faulty battery charger
Ensure the battery charger is functioning properly when a battery is connected and plugged into the wall. The light on the charger should illuminate red while charging and turn green when finished charging. If this is not the case, a new charger may be necessary.
Faulty Battery
The battery may have been damaged, so make sure to check that your battery is free of any damage before using it. If it is, then follow these steps to replace the battery: unplug the battery to the parrot bebop drone power cable; If necessary, pull the string to access the power cable; Then, slide a new battery into its compartment and finally attach the strap to secure the battery.
Unstable Flight
The drone is not stable during takeoff and flight.
Tilted During Takeoff
Be sure to hit Flat Trim before each flight, which is located on the top left corner to the right of the Settings icon in the FreeFlight Pro app. If that does not work, restart your drone by simply turning it off by pressing the power button, or by unplugging the battery, then powering it back on again.
Weak Signal
Since certain obstacles, such as buildings and powerlines, can interfere with the drone’s WiFi connection, simply try a new location which does not have as much obstacles.
Misaligned Gyroscope
Using the FreeFlight App, go into settings and the press “Calibrate”. Then follow the instructions by replicating the animations shown. Once all the axes are shown as valid, the calibration is complete.
Improper Propeller Placement
Make sure the propellers are in the correct position. Make sure the front-right and the rear-left motors have propellers with holes in the middle. The front-left and the rear-right motors should have propellers without holes in the middle.
Drone does not power on
The AR Drone does not power on when the battery is connected.
Faulty battery
Check to make sure the drone's battery is correctly seated and fully charged.
Faulty main board
If the drone still does not turn on after following the previous steps, the main board on the drone may be faulty and need replacement.
Kristen Gismondi
108,810 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
68 Comments
Bebop 1 not connecting to freeflight pro but can see WiFi signal
Lem Wright - Reply Share
I'm having the same problem please tell me you figured it out
John Langston - Reply Share
Hello
Can someone help i'm having the same prob
saad belhadi - Reply Share
Bebop1 will’nt stay connected after being connected …
Anthony Nance - Reply Share
I keep on losing Wi-Fi connection. It Conects and turns off.
roadrunner57 - Reply Share
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 56
All Time: 49,979
