Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Will Not Connect to Wi-Fi
The device cannot see or connect to nearby wireless networks.
Incorrect Wi-Fi or Network Settings
Either the Wi-Fi or Network settings on your computer are not set correctly. Navigate to Wi-Fi settings to ensure that Wi-Fi is enabled on your device and that you can see nearby networks. If you are connected and still cannot access the internet, navigate to your network settings and ensure they are correctly set.
Faulty Wi-Fi Card
If your device cannot see any local networks yet you can still connect fine using an Ethernet cable, you may have to replace your Wi-Fi/Bluetooth card. A guide on how to do this can be found here.
The Display Is Not Correct
Integrated or external display is incorrectly displaying desired output.
External display is blank or not displayed correctly
Check to ensure that the cable connecting your monitor to the laptop is connected firmly in place. Ensure that any screws on your cable headers are tightened down if they exist. It may be necessary to test the cable, external display, or both using another device to ensure they are functioning properly.
Blurry or Fuzzy Screen
Ensure that the display resolution for your monitor is correctly set. This can be adjusted in Windows by right clicking your desktop and selecting “Display Settings”.
Graphical Artifacting
If your screen is showing a checkerboard pattern of squares, dots, or lines, wildly incorrect colors,  or large patches of stuck pixels, your computer’s drivers may not be up to date. Ensure that you have installed the latest and correct drivers for your specific version of windows.
Keyboard Is Unresponsive
Keyboard is not responding, appears to be broken, missing keys, or keys are stuck in the up or down position.
Keys Are Stuck In Place
If one or all of the keys are stuck in place, then there might be something physically holding the key up or down. If a key is stuck like this, begin by removing the key from its slot. Visually inspect under the key for anything that would obstruct the key’s movement. Clean the area and double check there is nothing inhibiting a keystroke or underneath the key itself. Check for any sticky or viscous residue that might hold the key in place and make sure to clean that from the keyboard as well. Once thoroughly cleaned, snap the removed key back into place and test the key’s functionality again. If the key continues to remain stuck, check the keys immediately surrounding the key in question and inspect if they are impeding the stuck key. If not, consider replacing the keyboard with a new one.
Keys Are Broken or Missing
If there are keys missing from the keyboard, or keys are broken or cracked, they will need to be replaced. Attempt to locate the missing key. If unable to find it, a similar one will have to be purchased. Make sure it is the correct dimensions as the device’s keys and has the appropriate letter, number, or symbol printed on it. Align the new or found key over the space it is suppose to be within on the keyboard. With the appropriate connection, the key should gently snap into place with steady and gradual pressure directly over the center of the key.
Not Responding to Any Keystrokes
Attempt to clean the space under each of the keys first and check for any other hardware issues. Next, try reinstalling the keyboard driver by going to Device Manager, scrolling down to Keyboards, and open that setting. If there is an exclamation mark next to “Standard PS/2 Keyboard”, then Windows has detected a problem with the keyboard. If so, right click on “Standard PS/2 Keyboard”, and if there is an available update, enable it. If that too fails, uninstall the keyboard and reboot your computer. Also try uninstalling secondary keyboards that might appear under the device manager. To test keyboard hardware, try to boot into the BIOS while starting up. Make sure to press the correct key, usually F2, F8, or F12 repeatedly to boot into the BIOS. If booting into the BIOS fails and the device boots into Windows instead, that means there is likely a loose or disconnected cable on the motherboard Use this guide here to replace or reconnect the Panasonic Toughbook CF-53 keyboard.
Device Is Not Booting into Operating System
Device turns on but does not load the operating system.
Battery Has No Charge or the Battery Is Missing
If the battery is missing, find or buy a compatible battery and place into the battery slot. If the battery is present, plug in the power adapter and charge the battery. If the battery is not holding a charge then you can replace it by using this guide.
Device Is Set to Boot into BIOS Before Booting Into OS
Select the Boot tab in the BIOS setup and move your Operating System above the BIOS in boot order. Then select the OS and either double click or press enter. The device should now boot into your primary OS.
Hard Drive Is Corrupt
If the device is booting into an error message for a corrupt hard drive or Operating System files, you can either use a USB Boot Drive or replace the hard drive with a functioning one with an OS installed.
RAM Is Malfunctioning or Not Installed Properly
It is possible that an error has occurred with the computer’s Random Access Memory, whether that be with the RAM itself or the way it was installed. If this is the case, it will be necessary to replace the RAM with this guide here.
Optical Drive Is Not Reading Discs
The laptop is not reading or writing inserted discs correctly.
Optical Drive Is Faulty
Ensure that the disks are properly installed and functional. If the discs in question are confirmed to work in another device, the most likely cause is due to some form of fault in the optical drive itself. In this case it will be necessary to replace the optical drive as is shown in this guide.
Author
with
Nick Cyr
296 Reputation
0 Guides authored
8 Comments
Device not turning on. Battery good. Turned on yesterday morning. Closed the lid . Tried to turn on this morning it fails to turn on. It just sits on sa table.
Charles Smith - Reply Share
Replied ? I need the answer.if you can .
Lance Peterson - Reply Share
Did you ever get an answer to this. I had two computers do the exact same thing!
Rach - Reply Share
Mine is doing the same thing.. Green light is on indication full charge on battery, but will not turn on. Worked on Sunday, last time I used it. Power switch problem?
Duncan Campbell - Reply Share
Asking for startup password,12 years since used. Forgotten password can anyone help?.
Jim Mooney - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 105
All Time: 19,265
