Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Will Not Turn On
If your device is not powering on or appears dead and unresponsive
Battery Charger Cable And Connector May Be Damaged
If your Palm Zire M150 is not powering on or appears dead and unresponsive, first check to make sure your battery charger and adapter are functioning properly and that there are no cracks, cuts, broken or frayed wires on the cable or power unit. If the green power light does not come on when plugged in, you may have a faulty charger, causing the battery to not charge and the device to be turned off.
A Soft Reset Is Needed
If you find your charger unit is functioning properly but your device is still not powering on, you may begin by trying a soft reset. All of your information and records will be retained after a soft reset. To perform soft reset, locate the small reset button on the back side of your handheld device. Use a pin, needle, paperclip, or similar object to insert into the reset button and hold. If successful and you have power, the screen will indicate that the reset has been completed.
Lithium-Ion Battery Is Damaged
Finally, if all above measures have been performed and nothing has changed, you will have to take apart your Palm Zire m150 and check the connection or possibly change the internal lithium-ion battery. To do this, please refer to our repair guide section.
Screen Frozen Or Unresponsive
If your device screen will not respond to any commands
Battery Connection Is Corroded
If your handheld device screen is black and unresponsive, first check to make sure your battery charger and adapter are functioning properly. If the green power light does not come on when plugged in, you may have a faulty charger, causing the screen and device to be turned off.
If you find your device is no longer responding to buttons or the screen and there is no problem with the battery, you may begin by trying a soft reset. All of your information and records will be retained after a soft reset. To perform soft reset, locate the small reset button on the back side of your handheld device. Use a pin, needle, paperclip, or similar object to insert into the reset button and hold. If successful, the screen will indicate that the reset has been completed.
A Hard Reset Is Needed
If a soft reset does not remedy problems with screen responsiveness, it may be time to do a hard reset. Please note that a hard reset will erase all data and return device to factory settings. A hard reset should only be a last resort after all other measures have been taken. To perform hard reset, press and hold the power button while simultaneously inserting a pin to the previously explained reset button. You may release both once the Palm Powered logo appears on your screen. Your phone will be restored to default settings, retaining only the date and time. If this does not work, you may need to replace the screen. Please refer to our repair guide in order to do this.
Front Buttons Not Functioning
If your device will not respond to the buttons
Buttons Have Debris In Them
If you find it hard to press the front buttons on your device, you simply clean the space between the buttons using compressed air. If there is sand or dirt in the spaces you can also use a thin piece of paper to shovel it out.
If you find that your screen is working, but the buttons are not functioning you may need to do a soft reset. To do a soft reset, locate the small reset button on the back side of the device. Use a pin-like object to insert into the hole, and keep it in there for 3 to 5 seconds. After you release the pin, your device should indicate the reset is complete. Make sure that the buttons are now functioning.
Buttons Are Broken
If the buttons are still not functioning after cleaning the buttons and performing a reset, you may have to replace the buttons. Please refer to our repair guide to complete this task.
Device will not charge
If your device will not charge or keep a charge
USB Is Not Plugged In
Make sure the USB cable is connected securely to your handheld and to a working USB port of your desktop or laptop
Connectors are damaged
The device connectors could be either damaged or bent in a way that they can not perform correctly. Since the connectors are attached to the motherboard, you may have to replace the motherboard. Please refer to our repair guide in order to replace the motherboard.
Battery is dead
Your battery may have reached the point where it is dead and can longer hold a charge. Please refer to our repair guide in order to replace your battery.
No sound coming from the device
If you can't hear any sound coming from your device or in your headphones
Headphone jack is dirty
Make sure your headphone jack is free of debris. Lint and dirt often build up in there over time. Take a compressed air can and spray it in there.
Headphone jack is broken
For unknown reasons, sometimes the headphone jack stops working over time and it is time to replace the jack itself. Please refer to our repair guide in order to replace the headphone jack.
Author
with
Kate
528 Reputation
5 Guides authored
2 Comments
The following message appears on my computer when I attempt to perform a HotSync from my handheld Zire 21. I have Windows10 OS.
The log file C:\Program Files (x86)\Palm\BZ\HotSync.Log cannot be found. How do I fix this error?
Zachary Ansley - Reply Share
If I cannot perform a HotSync on my desktop computer that Palm 21 is installed is it possible to download or export the address book, expense file, etc. and install them on my laptop on which I just installed the Palm 21 software?
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 34
All Time: 2,117
