Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The device will not power on
The device will not respond or show any sign of powering up.
The device is not charged
Plug in the device and wait for it to charge.
The device needs to be reset
Press and hold the power button for 5-10 seconds.
The battery is faulty
Follow the Onda V701 Battery Replacement guide to replace the battery.
The device will not charge
The battery will not charge when the device is plugged in.
The charging cable needs to be reset
Unplug and check to make sure no foreign objects or debris are present in the connector. If necessary, clean out the connector. Then, re-plug in the charging cable and ensure that it is properly seated.
The charging cable is not working
The charging cable could be bad. Try using a different charging cable.
The battery connections need to be checked
Follow the Onda V701 Battery Replacement guide to gain access to the battery. Ensure the battery connections are not loose. If they are, re-solder them.
The screen is unresponsive
The picture on the screen is stuck on an image and the screen is unresponsive.
Hold down the power button for 5-10 seconds to perform a soft reset.
The device will not power off or reset
Wait until the battery runs out and then recharge the device. Then, turn the device back on.
The screen is distorted
The picture on the screen is distorted, it is possibly broken or cracked.
The screen is distorted but does not appear to be physically broken
If no damage is suspected, perform a soft reset of the device by holding the power button for 5-10 seconds.
The screen is cracked or broken
Follow the Onda V701 Screen Replacement guide to replace the screen.
The speaker is faulty
No sound coming from the device or the sound is distorted.
The device volume is all the way down
Press the volume up button to set the volume on high.
The device sound needs to be checked
Plug in headphones and compare that audio to the speaker. This will test if the speaker is broken.
Follow the Onda V701 Speaker Replacement guide to replace the speaker.
The front-facing camera is not properly working
The front-facing camera takes poor quality pictures or does not work at all.
Clean the lens on the outside of the device. If the quality does not improve, follow the Onda V701 Front-Facing Camera Replacement guide to remove the front-facing camera and clean it.
The front-facing camera does not work at all
Follow the Onda V701 Front-Facing Camera Replacement guide to replace the front-facing camera.
How to reset the device when problems are occurring.
Hold the Power Button for 5-10 seconds to perform a soft reset.
The device firmware needs to be updated
Check to see if the firmware is up to date and if not then update it.
Visit Onda V701 Tablet FAQ and scroll down to the questions section for information on updating the firmware.
Author
with
Bradley Huber
366 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,043
