Up to 20% off select tools
Onda V701 Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
19
Past 30 Days:
90
All Time:
1,068
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will allow you to remove the screen from the inside of the device in order to clean it or replace it. The screen on a device can easily crack. This repair is easy to do and does not require any special tools.
    1. Onda V701 Screen Replacement, Back Panel: step 1, image 1 of 3 Onda V701 Screen Replacement, Back Panel: step 1, image 2 of 3 Onda V701 Screen Replacement, Back Panel: step 1, image 3 of 3
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      Ask FixBot
    2. Onda V701 Screen Replacement: step 2, image 1 of 3 Onda V701 Screen Replacement: step 2, image 2 of 3 Onda V701 Screen Replacement: step 2, image 3 of 3
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      Ask FixBot
    3. Onda V701 Screen Replacement: step 3, image 1 of 2 Onda V701 Screen Replacement: step 3, image 2 of 2
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      Ask FixBot
    4. Onda V701 Screen Replacement: step 4, image 1 of 2 Onda V701 Screen Replacement: step 4, image 2 of 2
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      Ask FixBot
    5. Onda V701 Screen Replacement: step 5, image 1 of 3 Onda V701 Screen Replacement: step 5, image 2 of 3 Onda V701 Screen Replacement: step 5, image 3 of 3
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      Ask FixBot
    1. Onda V701 Screen Replacement, Screen: step 6, image 1 of 3 Onda V701 Screen Replacement, Screen: step 6, image 2 of 3 Onda V701 Screen Replacement, Screen: step 6, image 3 of 3
      • Remove all 14 of the 3.6mm screws using a PH00 screwdriver.
      Ask FixBot
    2. Onda V701 Screen Replacement: step 7, image 1 of 3 Onda V701 Screen Replacement: step 7, image 2 of 3 Onda V701 Screen Replacement: step 7, image 3 of 3
      • Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
      Ask FixBot
    3. Onda V701 Screen Replacement: step 8, image 1 of 3 Onda V701 Screen Replacement: step 8, image 2 of 3 Onda V701 Screen Replacement: step 8, image 3 of 3
      • Remove the grey monitor from the glass screen cover by gently lifting it up.
      Ask FixBot
Author
with
William Sioholm
104 Reputation
1 Guide authored
1 Guide Comment
بدي من هي الشاشة وين بلاقي
abdurrhman khrrat - Reply Share
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 90
All Time: 1,068
