Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Will Not Turn On Or Turns Off Unexpectedly
Even after pressing the power button, the camera will not turn on, or it will turn off without the power button being pressed while in use.
Power is off
Press the POWER button until the camera turns on.
Battery power is exhausted or installed incorrectly.
Ensure batteries are fully charged and installed correctly, if not, install new batteries. For hep, refer to Olympus SP-320 Battery Replacement
Outside temperature is too cold for batteries to function properly
Warm the batteries by putting them in your pocket for several minutes.
Camera is in sleep mode
Press the shutter button or press the zoom lever.
Camera is connected to a computer
Disconnect camera from computer. Camera will not operate when connected to a computer.
Batteries Die Quickly
''The camera is on and functioning, but the battery power drains quickly despite seeming to be fully charged.
Low Quality batteries
Use rechargeable batteries, such as CRV3 batteries.
Camera is being used in a cold environment
Battery life decreases in cold temperatures. Hold camera in your coat when not in use.
Battery life is not correctly displayed on screen
When battery consumption fluctuates the camera may turn off without giving a low battery warning. Insert new batteries. For help, refer to Olympus SP-320 Battery Replacement
No Picture Is Taken When the Shutter Button is Pressed
After pressing the shutter button, no photo appears on the LCD screen and no new photos can be found in the camera reel.
Internal memory or card is full
Insert new card. Or, download pictures to a computer then erase them from the camera.
Pictures You Have Taken Do Not Appear on the Monitor
After pressing the shutter button, no photo is visible on the LCD monitor screen.
Camera is in the shooting mode
Exit shooting mode.
Disconnect from computer. Camera does not operate when connected to a computer.
No pictures in the internal memory or on the card
Begin taking pictures.
Pictures Do Not Appear Saved on Memory Card
''Looking through the camera reel, there are no pictures.
Memory card slot may be broken
Replace memory card slot.
Flash Not Working
The flash does not go off when trying to take pictures in dark environments or to illuminate a scene.
Flash setting is not on
Select a flash mode, other than the flash symbol struck through.
Subject is illuminated
Select the flash mode that is only the flash symbol, with no other markings.
Camera is recording a movie
The flash does not fire in the movie mode. Select a shooting mode other than movie mode.
Super macro mode is set
The built-in flash does not fire in the super macro mode. Set the macro mode to OFF.
Panorama mode is set
The flash does not fire in the panorama mode. Cancel panorama mode.
Shutter Does Not Close or Retract
The shutter will not retract after turning off the camera or switching to a different shooting mode.
Shutter lag or shutter delay may be caused by broken lens
Replace lens.
Author
with
Brenna McCullough
409 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 1,377
