Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Controller Won't Connect to Shield
My controller will not connect or will not stay connected for long to my Shield
Shield Turned Off
Your Shield device may be off. Make sure your Shield device is turned on by checking to see if the device’s light is turned on.
Low Batteries
The battery in your controller might be low or dead. If the battery is low/dead, then the wireless connection to the Shield device will be weak, thus not connecting to the device. You should charge your controller, then try again. If the controller will not charge, your battery might be dead and will need to be replaced. You can check out our Battery Replacement Guide to replace your battery.
Parts: Nvidia Shield Controller Battery, Nvidia Shield Controller Charging Cable
Controller Is Not Synced
If the controller is not accurately executing the commands your are telling it to, it may not be in sync. Touch and hold the power button on the Shield’s device until the “connect accessory” screen appears on your TV and the light on the device is flashing. Make sure your controller is unplugged, then touch and hold the NVIDIA button on your controller until it flashes. The controller should connect after a few moments. If the button did not flash, please charge your controller then try again. Try holding Back + Home + the Shield button (or mic for the remote) for 15 seconds to "reboot" the controller. You'll notice the lights blink a slightly different pattern when it restarts.
Too Many Controllers Connected
Ensure that you do not try to connect too many controllers to the device. The connection limit for a single Shield’s device is four Shield controllers.
Controller Is Not Updated
Make sure your Shield controller is updated. To manually check for updates, navigate to Settings > About > System Upgrade.
Black Screen Showing on TV
Whenever I turn on my Shield, a black screen appears with the text "No Output"
Loose Cables
Ensure that the HDMI is securely plugged into the corresponding spots on both the Nvidia Shield and the TV or monitor. If the HDMI is plugged into the correct spot and there is still a black screen, try a different HDMI cord as the one you are using may not be functioning properly.
Part: HDMI Cable
Damaged Ports
It could be possible that the port on the Nvidia Shield that connects to the TV is damaged. In this case, you would have to replace the entire I/O board that holds all the ports within the Nvidia Shield, as they are all connected. Please check out the I/O Board Replacement Guide. Note that it could also be your TV’s ports that may be damaged.
Faulty Motherboard
If you are certain that the HDMI is plugged in correctly, you may have a faulty motherboard. You must replace the motherboard completely. Please check out the Motherboard Replacement Guide on how to replace it.
Audio Missing or Not In Sync
I can't get any sound to play through my TV or the sound is not in sync when connected to my Shield
Volume muted
Volume may be muted on the television, ensure the volume is up.
Improper Audio Settings
If the audio does not seem to be accurate with what is being seen on the screen, your audio is probably out of sync. Go into the advanced settings found within the Shield interface and select Audio Video Sync and use the slider to properly adjust the sound so it matches and is in sync.
Loose HDMI Cable
The HDMI plug, which displays the visuals and audio onto the TV, may not be properly secured to either the TV or the Shield. Ensure that the plug is properly connected to the TV and the Shield. If it continues to not work, the ports on the shield may be damaged. In this case, the I/O Board with all the ports must be replaced as they are on the same piece. Please check out the I/O Board Replacement Guide.
Out of Date Software
Ensure that the device’s software is completely up to date, if not try updating it. To manually check for updates, navigate to Settings > About > System Upgrade in your device. If your device is up to date and there is still no sound, try completely unplugging and restarting your Shield. If nothing above works, a factory reset may fix the problem.
Controller Won't Turn On
No matter how many times I push the power button, my controller will not turn on
Controller Has Low Battery
Your controller may have a low battery. Try plugging in your controller to charge.
Controller Unpaired
You controller may not be paired to your Shield device. To pair your device, touch and hold the power button on the Shield’s device until the “connect accessory” screen appears on your TV and the light on the device is flashing. Make sure your controller is unplugged, then touch and hold the NVIDIA button on your controller until it flashes. The controller should connect after a few moments. If that doesn't work, try holding Back + Home + the Shield button (or mic for the remote) for 15 seconds to "reboot" the controller. You'll notice the lights blink a slightly different pattern when it restarts.
Defective Charging Cable
Your charging cable may be defective and not work. Make sure the cable is not damaged and there are no protruding wires. If so, you will need to buy another charging cable.
Part: Nvidia Shield Controller Charging Cable
Faulty Battery
Your battery in your charger might be completely dead. If so, it will need to be replaced. Please check out our Battery Replacement Guide to replace your battery.
Part: Nvidia Shield Controller Battery
Device Won't Connect To Wi-Fi
My shield will not connect to my router
Wi-Fi Disabled On Shield
You may have Wi-Fi disabled on your Shield device. Make sure the Wi-Fi settings on the shield are turned on by going into your device's settings.
Improper Router Channel
The issue may arise from a problem with your router. Try changing the channel settings on your router.
Jessica Tran
783 Reputation
2 Guides authored
USF Tampa, Team S16-G6, Eyestone Fall 2017 Member of USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Members
72 Guides authored
4 Comments
it may sound silly, but after spending a long time trying to fix this problem of the controller not working…..I simply:
1) plugged the controller to the tv box with the original cable and
2) controller worked fine and
3) I then disconnected the cable and controller now working fine.
Can’t believe I did not do this obvious step right away, but kept charging controller with a plug thinking that it was not charged enough…..even tried leaving it charging over night!! HAHA :)
Carlo de Mattia - Reply Share
Mine just reset on its own and is now asking what country to sel3ct like it started over but I click it and it says it can't connect to internet even though I was just using it perfectly minutes ago! 2hat happened? I can't even get to home screen to factory reset! PLz help!
plttyp6 - Reply Share
I was just watching a show on YouTube and was just watching a movie on kodi right before and have had no issues for 2 years with this, and then all of a sudden everything froze so I unplugged and plugged Nvidia shield TV back in, and it went back to the screen saying welcome and asking what country to choose. When I choose mine, it keeps searching and says can't connect either with ethernet or wifi, yet I hit hack button and it says connected but won't bring me to home screen , just back to welcome screen. But if I hit the circle button twice, it'll also still bring me to my most recent used and YouTube is one, and it works still! But I can't get back to home screen in order to use anything else on the box!!! What's going on?!?! I've never had a problem once before! And I can't even factory reset now either, as I also don't own a computer. This is the 2015 500gb model…. II aalso tried using a controller and having it plugged straight in. Please help!!!
Rebooting and pairing procedures did not work my remote. Remote is useless.
Norberto Soto - Reply Share
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 88
All Time: 86,830
