Nvidia Shield TV 1st Generation Controller Battery Replacement
    1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: step 1, image 1 of 2 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: step 1, image 2 of 2
      • Remove the indicated six screws using the T6 Torx screwdriver.
      Ask FixBot
    2. Nvidia Shield TV 1st Generation Controller Battery Replacement: step 2, image 1 of 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to pry the face of the controller away from the body.
      • Make sure the controller is face down during this step as the buttons can easily fall out.
      Ask FixBot
    3. Nvidia Shield TV 1st Generation Controller Battery Replacement: step 3, image 1 of 1
      • Carefully remove the indicated ribbon wires from the face of the controller.
      Ask FixBot
    4. Nvidia Shield TV 1st Generation Controller Battery Replacement: step 4, image 1 of 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
      • Lift the vibration motor out of the front case.
      • Repeat for the other side.
      • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
      Ask FixBot
    5. Nvidia Shield TV 1st Generation Controller Battery Replacement: step 5, image 1 of 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 5, image 2 of 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 5, image 3 of 3
      • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
      • Lift the logic board away from the front case.
      Ask FixBot
    6. Nvidia Shield TV 1st Generation Controller Battery Replacement: step 6, image 1 of 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 6, image 2 of 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: step 6, image 3 of 3
      • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
      • Remove the panel from the front case.
      • Lift the battery from the front case to remove it.
      Ask FixBot
12 other people completed this guide.
Joshua Neally
581 Reputation
4 Guides authored
USF Tampa, Team S16-G6, Eyestone Fall 2017 Member of USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Members
72 Guides authored
8 Guide Comments
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Reply Share
LC18650 Remote Control accu
djcornelissen - Reply Share
Are battery packs available for the 2017 controller?
Andrew - Reply Share
Simply reconnecting the battery fixed my issues
Charles Keisler - Reply Share
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 76
All Time: 21,763
