Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Nobis NB09 Troubleshooting
Nobis NB09 9" internet tablet. This tablet comes with a 1.5GHz Cortex A9 processor, 1 GB Ram, and 8GB storage. Powered by Android 4.1.
Nobis Tablet is frozen
The tablet is stuck on the loading screen
Software glitch
Reboot the table by holding the power button, then powering it back on. If this does not work, try again while the tablet is connected to a charger or a computer. If this does not work, press the reset button on the back of the tablet. This will factory reset the tablet. If none of the above works, check the battery using this guide.
Nobis Tablet will not turn on
The tablet is not responding to the power button and will not turn on
Drained battery
If the tablet does not turn on, the battery may be out of power. Connect the tablet to a charger or a computer and wait a couple of minutes. Press the power button to see if the tablet will turn on.
Faulty battery
If the power button works, and the tablet will still not charge, disassemble the tablet using this guide. Check the battery to make sure it is installed properly. If it is, then the battery may need to be replaced. Follow this guide to replace the battery
Nobis Tablet will not charge
The tablet shows no indication that the charger is working
Faulty outlet
If your tablet is not charging, first check to see if you are using a faulty outlet. Unplug your device and move the charger to another outlet and see if the device will then charge.
Faulty charger
There may be an issue with the charger itself. Check the cable, and make sure there are no cuts or frayed wires. If the charger is worn out, it will need to be replaced.
Faulty battery
Use this guide to check that the battery is installed and working properly. If not, the battery may need to be replaced.
No audio from the Nobis Tablet
There is no sound coming from the tablet or attached headphones
Volume controls and options
If there is no sound coming from the device, check the volume button located on the side of the tablet and change it accordingly. Changing the audio options in the tablet may also help to fix the issue.
Headphones not connected properly
If there is no sound coming through the headphones, first check the audio options on the tablet. If the audio options are correct, then make sure that the headphones are connected properly in the auxiliary port. If the problems persists, there may be an issue with the headphone port or the headphones themselves.
Faulty speaker
If the above solutions do not work, then there may be a problem with the tablets speakers. Follow this guide to replace the speakers if they are faulty.
No WiFi on the Nobis Tablet
The tablet will not connect to WiFi
WiFi connection
Make sure that a strong connection in the area is present while connecting the device with a certain network as well as having the correct network key in order to link with it. Checking signal strength on the WiFi or Connectivity options may also help in fixing the issue.
Faulty WiFi card
Another problem might be a defective WiFi card on the Nobis Tablet. Check the WiFi card located on the back of the device. If card is faulty, please consult the warranty or call customer support.
Author
with
Sergey Kasyanov
237 Reputation
2 Guides authored
6 Comments
Nobis NB09 has no storage after factory reset. Can't download updates or anything. Will not shut down have to Force shut down. Did factory reset many times just to get it to start again and 4 more times but still no storage space. I need a system hack?
tenncoin - Reply Share
I have same problem....please tell me if you have found solution to that. Thanks
joe - Reply Share
Will not update apps
Norvella Bailey - Reply Share
I put a new screen on my nobis tablet and the home panel with the go back doesn't work. Thanks
peggy murrell - Reply Share
My tablet is stuck on nobis I tried to factory reset it nothing seems to be working how can I get pass that my nobis 9" tablet won't do anything
Michael Trunnell - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 5,658
