Nobis NB09 Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
102
All Time:
3,580
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in an Android Nobis NB09 tablet.
Some possible symptoms which could show that your tablet's battery is dying include:
  • Battery is at a low percentage even after a fresh charge.
  • The tablet dies when it still has a lot of battery life.
  • The tablet becomes hot after using for a short period of time.
If you experience any of these symptoms, then it is likely the culprit is a failing battery.
Tools
    1. Nobis NB09 Battery Replacement, Battery: step 1, image 1 of 1
      • Before beginning this process, make sure the device is powered off.
      • Remove the screws holding the case together.
      Ask FixBot
    2. Nobis NB09 Battery Replacement: step 2, image 1 of 3 Nobis NB09 Battery Replacement: step 2, image 2 of 3 Nobis NB09 Battery Replacement: step 2, image 3 of 3
      • Use an opening tool to loosen and pry off the pink back plate.
      Ask FixBot
    3. Nobis NB09 Battery Replacement: step 3, image 1 of 2 Nobis NB09 Battery Replacement: step 3, image 2 of 2
      • Remove the black electronic tape covering the circuit board.
      Ask FixBot
    4. Nobis NB09 Battery Replacement: step 4, image 1 of 1
      • Use the soldering iron to remove the black and red wires from the circuit board.
      • The black wire is the ground and the red wire is the battery positive terminal.
      • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
      Ask FixBot
    5. Nobis NB09 Battery Replacement: step 5, image 1 of 2 Nobis NB09 Battery Replacement: step 5, image 2 of 2
      • Gently loosen the adhesive under the battery to avoid damaging it.
      • Use caution; the battery is soft and will bend very easily.
      • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
      • When reassembling, apply adhesive to the back of the new battery.
      Ask FixBot
3 other people completed this guide.
Jackson McAdams
390 Reputation
3 Guides authored
1 Guide Comment
where can i buy a battery from
Frederick Shipman - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 102
All Time: 3,580
