Nintendo Game Boy Advance Troubleshooting
Screen Cracked
If the screen appears to be cracked, or the display is black, white, or an assortment of colors, refer to our Screen Replacement Guide.
Sticky Buttons
If the buttons function improperly due to sticky residue, refer to our Cleaning Sticky Buttons guide.
If after this procedure the unit doesn't respond adequately then refer to our Button Repair Guide where we show how to take the buttons out for a superior cleaning.
Sound Problems
"Everything is running perfectly fine but I cannot hear the sound"
License Accessories
Some products are not compatible with Nintendo systems so make sure that you are using license accessories.
Incorrectly Plugged Headphone
Sometimes there might be something blocking the headphone port which prevents the connection from functioning properly.
Volume control
Adjust the volume. Other games require more volume than others.
Dead Batteries
If your batteries are dead then the system will not work at all. Refer to our Battery Replacement Guide
Speaker is broken
This problem is very rare but if you did all of the above solutions then your speaker is probably broken. Your Game Boy Advance will need to be repaired or replaced. To replace the speaker refer to our Repairing Speaker guide.
Power Problems
"Your Game Boy Advance will not turn on or turns on and quickly turns off."
Issues with the On/Off Switch
Make sure the On/Off switch is in the On position, towards the right. You may need to remove any debris that is keeping the switch from moving. If the On/Off switch needs to be replaced, refer to our On/Off Replacement Guide.
Check the Batteries
Look at the battery level indicator light located on the front of the Game Boy by the right shoulder button. If your device's battery indicator light is red, your batteries have less than a 30% charge. Normally the indicator light is green. Refer to our Battery Replacement Guide for assistance. Also be sure that the battery contacts are free of any corrosion.
Game Freezing
Blank Screen
1.) Consider the possibility of dead batteries, which would cause the game to turn off. In this case, refer to our Battery Replacement Guide. (There is not a brightness adjustment procedure for the Game Boy Advance)
2.) A poor connection between the game and the cartridge port could cause the screen to go blank. The problem could stem from the game or the cartridge port. Attempt to play another game to signify whether the port or the game is the problem.
Frozen Screen
1.) Make sure the items you are using are licensed accessories to Game Boy Advance. Unlicensed products might not be compatible and could cause the system to freeze.
2.) If this is not the problem, turn off your system and firmly reinsert the game into the game slot. A click should signify the Game Pack is firmly in place.
3) Once the game clicks in place, make sure the power switch moves all the way to the on position. If it does not, the game might freeze. If this is the case, refer to our On/Off Replacement Guide.
4) Next, try the same process with a different Game Pack to determine if the problem rests with the game or the system.
Freezing in Multiplayer Setting
1.) Make sure you are using the correct game link cable. While using the correct cable, turn off the power, re-connect the cable, turn the system on, and try the multiplayer setting again. The connection might have become loose prior to freezing.
2.) Make sure you have the same game in each system, otherwise freezing will occur.
Replacing the Logic Board
Replacing the Logic Board requires the use of a soldering iron and basic hand tools. Removal of the back cover is required to access the PCB. For this process, refer to our Installing the Logic Board Guide.
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
17 Comments
do you think were dumb or somthin we already know this stuff
byron - Reply Share
How can I get rid of corrison on my game boy advance. Does anyone know? Please I need help.
Jennifer Franklin - Reply Share
What type of corrosion are you talking about, Jennifer ?
Linchpin742 - Reply Share
Often hydrogen peroxide 100% is good to use. Be sure to use in small amounts such as on a toothbrush like I use.
Screech Undead - Reply Share
I got a GameBoy advance sp off of the Internet, it's in pretty good condition, but the power switch is loose, so sometimes it shows that it is red even though I just finished charging it. It gets confusing for me because sometimes when I'm plugging in without needing to. Any suggestions on how to fix this?
Trey westbrook - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 135
All Time: 66,730
