Up to 20% off select tools
Game Boy Advance Buttons Replacement
Views: 31K
View statistics:
Past 24 Hours:
10
Past 7 Days:
79
Past 30 Days:
384
All Time:
31,175
Comments: 1
1 guide comment.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace, upgrade, or customize the buttons in your Nintendo Game Boy Advance model AGB-001.
This guide covers how to replace the action (A + B) buttons, shoulder (L + R) buttons, D‑pad, and ON/OFF power switch cover, as well as the side bumpers.
If you're completely re‑shelling your Game Boy, follow this guide.
The Game Boy Advance uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
    1. Game Boy Advance Buttons Replacement, Prepare your Game Boy for disassembly: step 1, image 1 of 2 Game Boy Advance Buttons Replacement, Prepare your Game Boy for disassembly: step 1, image 2 of 2
      • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge installed, remove it.
      • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
      Ask FixBot
    1. Game Boy Advance Buttons Replacement, Remove the battery cover: step 2, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the battery cover: step 2, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the battery cover: step 2, image 3 of 3
      • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
      • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
      Ask FixBot
    2. Game Boy Advance Buttons Replacement, Remove the batteries: step 3, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the batteries: step 3, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the batteries: step 3, image 3 of 3
      • Remove the two AA batteries.
      • If the metal terminals are corroded, follow this guide to clean them.
      • When installing batteries, use the diagram in the battery well to properly orient them.
      Ask FixBot
    1. Game Boy Advance Buttons Replacement, Remove the back shell screws: step 4, image 1 of 2 Game Boy Advance Buttons Replacement, Remove the back shell screws: step 4, image 2 of 2
      • Remove the seven screws securing the back shell:
      • Six 9.4 mm‑long tri‑point Y0 screws
      • One 8.5 mm‑long JIS 1 screw
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
      Ask FixBot
    2. Game Boy Advance Buttons Replacement, Remove the back shell: step 5, image 1 of 2 Game Boy Advance Buttons Replacement, Remove the back shell: step 5, image 2 of 2
      • Lift the back shell straight up and remove it.
      • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
      Ask FixBot
    1. Game Boy Advance Buttons Replacement, Remove the shoulder buttons: step 6, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the shoulder buttons: step 6, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the shoulder buttons: step 6, image 3 of 3
      • Lift the shoulder buttons (aka L and R buttons) straight up to remove them.
      • During reassembly:
      • Since your Game Boy is laying upside down, the L button will go on your right‑hand side, and the R button will go on your left‑hand side.
      • Slide the buttons into place, making sure the peg on the button goes into its circular cutout and the button itself is over the actual button mechanism.
      • The shoulder buttons will sit on the inside edge of the side bumpers.
      • Gently test the buttons to make sure they feel correct. If they don't, reposition them and make sure the metal arms aren't stuck in a weird position under the board.
      Ask FixBot
    2. Game Boy Advance Buttons Replacement, Remove the side bumpers: step 7, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the side bumpers: step 7, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the side bumpers: step 7, image 3 of 3
      • Remove the side bumpers.
      Ask FixBot
    3. Game Boy Advance Buttons Replacement, Remove the power switch cover: step 8, image 1 of 2 Game Boy Advance Buttons Replacement, Remove the power switch cover: step 8, image 2 of 2
      • Remove the power switch cover.
      • During reassembly, make sure the switch cover is properly slotted around the arm on the switch mechanism.
      Ask FixBot
    1. Game Boy Advance Buttons Replacement, Remove the motherboard screws: step 9, image 1 of 2 Game Boy Advance Buttons Replacement, Remove the motherboard screws: step 9, image 2 of 2
      • Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
      Ask FixBot
    2. Game Boy Advance Buttons Replacement, Reposition the motherboard: step 10, image 1 of 3 Game Boy Advance Buttons Replacement, Reposition the motherboard: step 10, image 2 of 3 Game Boy Advance Buttons Replacement, Reposition the motherboard: step 10, image 3 of 3
      • Be careful not to strain the screen cable that connects the motherboard.
      • Carefully flip the motherboard over the top edge of your Game Boy and rest it on your work surface.
      • During reassembly, make sure the speaker gets correctly slotted into its circular cutout (including a small tab on the bottom) when lowering the motherboard into place.
      Ask FixBot
    3. Game Boy Advance Buttons Replacement, Remove the silicone pads: step 11, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the silicone pads: step 11, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the silicone pads: step 11, image 3 of 3
      • Use tweezers or your fingers to remove the three silicone pads covering the buttons (A and B, the D‑pad, and Start/Select ).
      • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
      • During reassembly, use your fingers to press each pad into place, using the alignment pegs to properly orient them.
      Ask FixBot
    4. Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: step 12, image 1 of 3 Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: step 12, image 2 of 3 Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: step 12, image 3 of 3
      • Use tweezers or your fingers to remove the buttons (A and B as well as the D‑pad).
      • The Start/Select buttons are part of the silicone pad—there are no other buttons to remove.
      • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
15 other people completed this guide.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
1 Guide Comment
If you have buttons that don’t respond, you can also just clean the contacts (the round black ones and the gold ones on the board) with alcohol and a Q-tip. After that, I coated the contacts with some contact spray, also with Q-tip. All buttons are working again.
Simon - Reply Share
Past 24 Hours: 10
Past 7 Days: 79
Past 30 Days: 384
All Time: 31,175
