Camera is Not Turning On
The camera is not responding or showing any sign of powering up.
Uncharged Battery
Your camera is most likely out of battery. Recharging the camera will solve this problem.
Dirty Battery Compartment
The battery compartment might be contaminated with foreign material. In this case, the compartment should be cleared or cleaned.
Faulty Battery
Your battery could be defective and you will need to purchase a new one.
Broken Screen
The screen displays unusual color or visual cracks.
Screen Discoloration
Try the factory reset option in your camera's menu as a possible fix. Otherwise, you will have to purchase a new screen and follow the replacement instructions of the Nikon Coolpix P90 LCD Screen Replacement guide.
Cracked Screen
Unfortunately, there is no way to repair a cracked screen without replacing the screen itself. After purchasing a new screen, you can replace it using the Nikon Coolpix P90 LCD Screen Replacement guide.
Flash is Not Firing
The flash is not working as usual.
Flash Setting is Disabled
Confirm that the flash is turned on. Enable the flash by pressing either the top button on the D-pad with a flash arrow symbol or the flash button on the side of the camera body to open the flash compartment.
Modes
Some shooting modes automatically have the flash setting turned off (i.e. Video, Landscape).
Low Battery
The flash setting requires a good amount of power, so make sure the battery is adequately charged.
Broken/Burnt Out Flash Bulb
The flash bulb may be burnt out and will need to be replaced. Use the Nikon Coolpix P90 Flash Bulb Replacement guide to help do so.
Problems Saving Pictures
Recently taken photos are not displaying in saved images.
Missing Memory Card
Ensure that your memory card is inserted in the camera.
Full Memory Card
Check if there is enough space on the memory card. If your memory card has no free space, you will need to transfer your memory card's data onto a laptop or CD, and delete the data on the memory card or purchase a new memory card. This camera is only compatible with SD and SDHC memory cards.
Camera Turns On But Doesn't Work
The camera seems to turn on, but does not function as expected, refusing to take pictures, failing to navigate the memory card, preventing access to the settings, or exhibiting other issues.
Bad motherboard
It's possible that the motherboard, which runs the camera's operating system, has been damaged. In this event, the entire unit must be replaced. Refer to the Nikon Coolpix P90 Motherboard Replacement guide for help.
Tyler Wong
97 Reputation
0 Guides authored
Cal Poly, Team 20-14, Maness Winter 2015 Member of Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Members
72 Guides authored
2 Comments
i have a nikon p90 coolpix..malfunctioned on vacation…when i turn it on now, the lense goes in and out, in and out, in and out..won’t stop, cannot turn it off…have to take out battery to do this…nothing registers on screen, total darkness…any idea? is the camera “shot” (no pun here)
BARB - Reply Share
Alberto Lavo - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 4,043
