Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera won’t turn on
The camera is unresponsive to attempts to turn it on
Depleted Batteries
The batteries may be depleted, try replacing them.
Batteries Facing the Wrong Way
The batteries may be improperly inserted. Check to make sure the 2 positive and 2 negative batteries are placed in their respective slots.
Battery Compatibility
The L840 can use AA size alkaline, lithium, and rechargeable Ni-MH batteries.
Faulty Battery Terminals
When replacing the batteries does not do the job, the fault may lie with the battery terminals. Try lightly cleaning the battery terminals with a dry material.
Faulty Memory Card
The memory card may be causing the device to have trouble turning on. Try turning the device on again without the memory card inserted, or with the memory card replaced.
LCD Screen is Not Working Properly
The screen is unresponsive
Screen not displaying anything
Replace batteries (AA batteries)
Turn off the camera and turn it back on
If the flash lamp is on, the flash is charging - wait until it is complete
To replace the LCD screen, check out our LCD Screen replacement guide.
Shutter Won’t Work Properly
The camera shutter is stuck or is unresponsive
Debris Obstruction
Make sure the lens is clean and nothing obstructs the shutter’s path. Use either microfiber or tissue and cleaner to carefully remove any debris, use compressed air around the lens and shutter area
Shutter Error
Try interrupting the shutter by setting the shutter speed as low as possible, then pulling out the batteries while the camera is still taking the photo.
Memory card cannot be read
The memory card cannot be accessed
Unapproved Memory Card
The following lists the memory cards that have been tested and approved for this camera.
  • SD Memory Card: Panasonic
  • SDHC Memory Card: SanDisk, TOSHIBA, Panasonic, Lexar
  • SDXC Memory Card: SanDisk, TOSHIBA, Panasonic, Lexar
Damaged Memory Card
Try using another approved memory card. First you want to turn off the camera, eject the memory card and then insert a new memory card. Make sure the card is inserted in the correct orientation otherwise you will get an error saying "unable to read card" on the LCD screen. Once the new memory card is inserted turn on the camera.
Card Not Correctly Inserted
Turn off the camera, eject the memory card, and reinsert until it clicks. Make sure the card is inserted in the correct orientation. There is also a label on the camera showing which way the memory card should be orientated.
Incorrectly Formatted Memory Card
Format the memory card using the camera or a computer. Connect the adapter onto the end of your memory card that converts it into the full size SD or MMC card. If you need a adapter simply click this link- http://goo.gl/adqSot . Then insert your card into the card reader and plug in the USB cable into your PC. After several seconds your memory card will be identified and then you want to right click and select "Format". Once you do that a dialog should pop-up and you click "Start". By following these steps you should be able to correctly format your memory card
Note: Make sure to backup any files in the memory card.
Lens cover won’t open
Debris stuck around the cover
  • Remove any debris that may be stuck in the lens cover. Use compressed air or a blow dryer (set to cold setting) to dislodge any debris.
  • Slip a thin piece of paper between the surface of the lens and its outer ring to dislodge any debris that may be stuck there.
  • Hold camera with lens barrel facing down, and tap the lens barrel to dislodge any debris. Repeat with lens extended and retracted.
Depleted Batteries
The batteries may be depleted, try putting in new batteries.
Buttons not Responding
Buttons do not respond when pressed, or respond incorrectly
Faulty Buttons
To replace the camera buttons, check out our Button replacement guide.
Chanelle Mosquera
289 Reputation
1 Guide authored
Cal Poly, Team 1-11, Maness Spring 2016 Member of Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Members
60 Guides authored
29 Comments
A problem with Setting. When Menu is open, section "Setting" provides only two options. How to open other?
embucr - Reply Share
When I turn my camera on it shuts off straight away or it just zooms in fully by itself and then it says 'Battery Exhausted' how do I fix this?
Bobby Lashley - Reply Share
My camera was working fine last night but when I went to plug it into my computer it stopped working. I've plugged it in before with no issues. I changed the batteries thinking maybe the batteries died. But it still wont turn on..
blare_cat - Reply Share
The quality of the photos are very grainy. Not sure if it's just the camera quality or a setting, it seems like I've tried everything. Would love some help.
Hannah Twomey - Reply Share
My camera won't turn on. New batteries. It was working the night before. Please help.
rochelle_ratliff - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 45
All Time: 17,976
