Nikon Coolpix L840 Buttons Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
97
All Time:
3,372
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide details the steps required to replace buttons on the back face of the camera. Please use this guide only when a specific button is not working. When the problem involves other parts of the camera or all of the buttons, you may need to replace a component of the circuit board.
Tools
    1. Nikon Coolpix L840 Buttons Replacement, Motherboard: step 1, image 1 of 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: step 1, image 2 of 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: step 1, image 3 of 3
      • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
      Ask FixBot
    2. Nikon Coolpix L840 Buttons Replacement: step 2, image 1 of 1
      • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
      • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
      Ask FixBot
    3. Nikon Coolpix L840 Buttons Replacement: step 3, image 1 of 2 Nikon Coolpix L840 Buttons Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
      • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
      Ask FixBot
    1. Nikon Coolpix L840 Buttons Replacement, Buttons: step 4, image 1 of 1
      • Unscrew the two, right-most, 2 mm screws with a Philips 000.
      • Unscrew the left-most, 4 mm screw with a Philips 000.
      Ask FixBot
    2. Nikon Coolpix L840 Buttons Replacement: step 5, image 1 of 1
      • Slide off the button panel in the marked direction.
      Ask FixBot
    3. Nikon Coolpix L840 Buttons Replacement: step 6, image 1 of 1
      • Flip to the front side of the button panel to access the button sensors.
      Ask FixBot
Abraham Lozano
610 Reputation
4 Guides authored
Cal Poly, Team 1-11, Maness Spring 2016 Member of Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Members
60 Guides authored
1 Guide Comment
Where can I get a replacement board for the buttons?
rush - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 97
All Time: 3,372
