Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera does not power on
When the on/off button is pressed the camera does not turn on
Low battery
If the camera does not turn on, check to see if the batteries are low. If they are low then see guide Nikon Coolpix L32 Batteries Replacement. If the batteries are not low, read on.
Batteries are put in backwards
If the batteries happen to be put in backwards then the device will not power on. See guide Nikon Coolpix L32 Batteries Replacement.
See guide “” for replacement.
Camera turns off suddenly
During use of camera it will turn off unexpectedly
Faulty batteries
If the camera does not turn on, check to see if the batteries are low. If they are low then replace the two AA batteries by opening the battery slot at the bottom of the camera. See guide Nikon Coolpix L32 Batteries Replacement
Overheating
If the camera is exposed to high temperatures for a long period of time while in use, it may overheat and suddenly turn off. Do not expose camera to direct sunlight for long periods of time. If exposure occurs then let camera cool in a dry place before continuing use.
LCD does not work
LCD screen does not show an image
Low battery
If the power button is pressed and no lights including the the LCD screen do not turn on then consider replacing the batteries of the device. See guide Nikon Coolpix L32 The LCD Screen Monitor Replacement.
LCD is broken
If the camera is turned on and does not display any image on the screen then the LCD screen must be replaced. See guide Nikon Coolpix L32 The LCD Screen Monitor Replacement
Camera is on standby mode
When the camera is on standby mode, the screen will look blank. To get the camera off of standby mode, press the shutter button.
Selector buttons not working
When pressing any of the buttons the camera is unresponsive
Selector buttons are stuck.
When pressing any selector buttons they get stuck. See guide Nikon Coolpix L32 Selection buttons Replacement
Camera does not take picture
The camera does not take any more pictures
Internal storage and memory card are full
The camera will not allow you to take any more pictures if the internal storage and the memory card is full. In this case the user should purchase an external memory card. See guide Nikon Coolpix L32 Memory Card Replacement
Simon Munoz
104 Reputation
1 Guide authored
USF Tampa, Team 2-4, Blackwell Fall 2016 Member of USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Members
60 Guides authored
1 Comment
Help!! My Coolpix L32's lens will not open when powered on.
Naomi Ratliff - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 1,458
