Nikon Coolpix L32 LCD Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
95
All Time:
1,535
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If the Nikon Coolpix L32 suffered from physical damages and it remains dark after trying to power it on, consider replacing the LCD Screen. No hazards are associated with this replacement.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 1 of 3 Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 2 of 3 Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 3 of 3
      • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
      Ask FixBot
    2. Nikon Coolpix L32 LCD Replacement: step 2, image 1 of 1
      • Open the battery compartment door and pull the black back face apart from the front red face.
      Ask FixBot
    1. Nikon Coolpix L32 LCD Replacement, LCD: step 3, image 1 of 1
      • Using the spudger, gently pull the LCD screen from the tray holding it.
      • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
      Ask FixBot
    2. Nikon Coolpix L32 LCD Replacement: step 4, image 1 of 1
      • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
      Ask FixBot
    3. Nikon Coolpix L32 LCD Replacement: step 5, image 1 of 1
      • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
      Ask FixBot
Sherika Jacobs
348 Reputation
3 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2016 Member of USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 95
All Time: 1,535
