Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Won’t Power On
When the power button is pushed, the camera does not power on. LCD screen is blank or has a flashing red battery symbol.
On Button Not Fully Pressed
The power button may require slightly more pressure to be applied to turn the camera on if the camera is older or used. This may be a result of debris or general wear from cyclic turning on and off of the device.
Low or bad battery
This device has an approximate battery life of 420 shots. The LCD should display a flashing red battery symbol if the battery pack is depleted enough to not be able to power up the camera. Attempt to charge to camera and try to power on. If the camera does not power on the battery pack may need to be replaced.
Cannot Take Picture/Video When Shutter Button is Pressed
Camera does not respond when shutter button is pressed
Playback Mode is On
The device will not take pictures or videos when it is in viewing (playback) mode. Take the device out of playback mode in one of multiple ways: by pressing the “c” button, pressing the shutter-release button, or pressing the “d” button.
Flash is Charging
Wait for the flash to finish charging. “Q” light will flash until the flash is fully charged, you should then be able to take a photo.
A/C Adapter is Connected
You cannot record movies when the A/C adapter. Remove the adapter to record video.
Memory Card Not Inserted/Full
Insert a memory card that has sufficient storage. If memory card is already inserted, remove it and re-insert it correctly.
Lens Error Message
A lens error message appears on the screen when powering on
Faulty Battery
Take out the battery currently in the camera and replace it with a new battery. If it powers on without the error, then the battery was faulty.
Dirt in Housing
With the camera off, place on a flat surface with the lens facing up. Inspect the camera lens for any dirt in the housing. Gently clean off anything dirt that would be in the crevices which could prevent the lens to fully extend.
Misaligned Lens Housing
With the camera off, place on a flat surface with the lens facing up. Inspect the lens housing making sure the housing is flush with the body of the camera. If there are any gaps visible, gently apply pressure on the housing until a click is heard.
Lens Doesn't Fully Extend
Turn the camera off. Hold with one hand and gently move the lens in a circular movement. Do the same with the other section of the lens and you’ll hear a click when it pops in place. Next turn on the camera and pull and twist the largest ring while turning on and listen for a click.
Broken Lens Apparatus
If the Nikon Coolpix B700 is still giving a lens error then the lens apparatus is broken and has to be replaced. Lens Replacement Guide
LCD Screen Won’t Turn On
Camera is functioning properly, but the display is not working.
Faulty/Dirty Eyepiece Sensor
The eyepiece sensor to the right of the viewfinder turns the screen on and off based upon the proximity of your eye. A smudged or dirty sensor may constantly trigger the viewfinder and turn off the screen.
Ribbon Not Connected
When cameras are dropped or used in harsh environments, electronic connectors might become loose and not make proper connections. The LCD Ribbon is the main source of communication between the screen and the device. To fix this problem, follow this guide.
Cracked Screen/Dead Pixels
Cracked or dead screens can be caused by user impacts, or the overheating of individual pixels. To fix this problem the screen will need to be replaced. To replace the camera’s LCD screen, please follow this guide: LCD Replacement
Flash Does Not Fire
Flash fails to fire when a photo is taken.
Shooting Mode Restricts Flash
Some modes do not enable the flash to fire when a photo is taken. Change to shooting mode to one where the flash is used.
Flash is Turned Off
Ensure that the flash is enabled, depending on the mode the camera is in. Auto flash may use the flash in some situations but not in others.
Flash Bulb is Burned Out
Flash bulb has burned out due to excessive wear. Replace the flash assembly using this guide: Flash Unit Replacement Guide
23 Comments
My camera B700 has been working OK for the last few years. However, Recently, the LCD still works OK, however, all the photos I took were black. Nothing else. Please help!
Quyen Truong - Reply Share
ive just had the same problem, did you find a solution?
Dan Thurston - Reply Share
When I download photos from my coolpix B700 into my computer, then try to share them, the recipients cannot open the photos. What to I need to do to format the photos so they can be shared?
sheila wasserman - Reply Share
I have blue and white bars instead of the photo on my screen. What happened?
I have tried reformatting, changing the SD card and powering on and off without success.
Robert Huxley - Reply Share
Same problem with me.. pink and white bars are coming .. please help
AIM Cine - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 39
All Time: 7,158
