Camera does not turn on
Battery is exhausted
Remove the battery from the camera and insert it into the supplied charging dock. Installing Nikon Coolpix 7900 Battery
Battery is defective
The Nikon Coolpix 7900 camera uses an EN-EL5 Lithium Ion Battery Pack. Replace the battery with the same battery type.
Monitor is blank
The Nikon Coolpix 7900 camera uses an EN-EL5 Lithium Ion Battery Pack. Replace the battery with the same battery type. Installing Nikon Coolpix 7900 Battery
Camera is off
Make sure the battery is charged and is inserted. Hold down the power button until a beep sounds and the display turns on.
Camera is connected to computer/TV via USB or audio/video cable
If the camera is connected to a computer via USB cable or a TV via audio/video cable, disconnect in order to view the display.
LCD screen is broken
If the LCD screen appears broken or does not turn on then the display may need to be replaced. Refer to our LCD disassembly guide in order to remove the LCD screen. Installing Nikon Coolpix 7900 LCD Screen
Lens does not zoom
Lens is jammed
If the lens appears to be jammed then there may be debris stuck inside the lens assembly. Refer to our Lens Case disassembly guide in order to remove debris. Installing Nikon Coolpix 7900 Front Cover
Zoom buttons are broken
If the zoom buttons appear to be broken or defective, they may need to be replaced.
Lens is broken
If the lens is cracked or otherwise broken, the lens may need to be replaced.
Flash does not work properly
Flash is turned off/on
Access the settings tab on the camera display and verify that the flash is turned on or off. Make sure to turn off the auto flash function for complete control over the flash. In addition, make sure the camera is not in video capture mode.
Flash bulb is depleted
The flash bulb may be dead and consequently would need to be replaced.
Charge capacitor is damaged
If the charge capacitor is damaged. The bulb will not be able to hold a charge. The capacitor will need to be replaced in this case. Installing Nikon Coolpix 7900 Front Cover
Pictures do not save
Memory card is not inserted
Verify that the memory card is in the camera.
Memory card is defective
If the memory card is damaged, it will need to be replaced. This camera uses a generic SD card. Installing Nikon Coolpix 7900 Memory Card
Camera/card memory is full
If the memory card is full, transfer pictures to an external storage device.
Kaky Payne
121 Reputation
5 Guides authored
Cal Poly, Team 12-38, Regan Spring 2012 Member of Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Members
60 Guides authored
2 Comments
My flash it wont close back. I can't put it back in the case.
Rafael Alazraki - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 23
All Time: 2,664
