Monitor is blank
Camera is off
Press the on/off button on top of the camera to turn it on.
Battery is exhausted
Use the multi-connector port (labeled AV out) to charge the camera.
Battery is bad
Nikon indicates the battery should last for around 290 shots per charge. If your camera is loosing battery charge much faster, it is likely your battery is bad. Follow the replace battery guide to fix this problem.
*Battery installation guide
Bad motherboard
Follow the replace motherboard guide.
*Motherboard installation guide
Broken LCD screen
Follow the replace LCD screen guide.
*LCD installation guide
Standby mode for saving power
If the camera is in Standby mode, press the shutter-release button halfway.
Camera and computer are connected via USB cable
The camera screen will be disabled when connected to the computer and must be unplugged before it can be used.
Camera and TV are connected via audio/video cable
The camera screen will be disabled when connected to the TV and must be unplugged before it can be used.
Camera Turns Off Without Warning
Battery is low
Charge the battery by connecting the charging cord to the multi-connector port labeled "AV out" on the side of the camera.
Battery is bad
Camera has turned off automatically to save power
The camera will turn off automatically if not used for a long period of time. Press the on/off button to turn it back on.
Battery is cold
On cold days the battery loses a great amount of charge, and when the temperature goes below 32 degrees Fahrenheit it will not charge.
Camera Won't Take Pictures
Battery is dead
Charge the battery and try again.
Battery is bad
Replace the battery
*Battery Installation Guide
Lens Assembly is Faulty
Replace the lens assembly
*Lens Assembly Installation Guide
Date and Time on Display Are Incorrect
When the date and time are not set, the words "Date not set" will blink during shooting.
All Settings Have Been Reset
If both the battery and the backup battery have been depleted, then the settings will all return to their factory defaults. Your preferred settings will have to be entered manually.
Daniel Stohr
1 Reputation
0 Guides authored
Cal Poly, Team 9-5, Regan Winter 2012 Member of Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,729
