Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Nerf Gun Won't Fire Nerf Darts
Chambers aren't getting enough air pressure
No matter what you do, you can't get your Nerf Bow to work properly.
Make sure you’re pushing your Nerf darts completely into the chambers, and they’re not loose. If the darts can't be pushed in completely, then make sure there are no item(s) or missing gum obstructing the chambers. If there is, simply remove and try again.
Foam Darts not manufactured by Nerf may not be compatible
Sometimes a simple check that you bought the right darts is helpful, and that they were made to fit in the Nerf gun you have. It doesn't hurt to check that nothing is in the holes of your darts.
Cocking device is not cocking
The cocking mechanism is not being pulled back far enough
Before delving into the guts of your Nerf gun, make sure the cocking device is working. Pull until you can't pull any further without dislodging the slide. If the cocking mechanism is not locking, then don't worry. Read below.
Wear and tear may impede the cocking mechanisms ability to lock in-place once pulled back the appropriate amount
The spring that allows your cocking mechanism to cock might be broken, so follow the instructions in this repair guide. The Nerf gun most likely got hit on a hard surface.
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
Trigger is Jammed
Parts inside the gun may interfere with the trigger motion as well as missing or dislodged pieces
If the trigger is jammed, fear not about replacing it; nobody sells it. Instead, it could be a broken spring that allows for the movement of the trigger. Any spring of similar size can be used as a substitute. If you open up the nerf gun and find the spring isn't broken, then follow this repair guide to see how to fix it back into place. Your sibling might have thought this was a cool looking bat, and decided to swing at some balls with it.
Nerf Zombie Strike Crossbow Trigger Spring Replacement
Bow String is Cut
Long-term use may cause the bowstring to snap
If the bow string was cut then know that it wasn't useful to begin with. 1) You can't buy it in local stores. 2) The trigger string serves more of an aesthetic purpose anyway.
Plunger is not Plunging
Excessive force or accidental damage can cause internal issues
Likely cause if your brother got a few good hits using the Nerf gun as a bat. Worry not. If you can't see any observable damage on the gun, then you might want to open it up to check for any damage on the inside. Simply follow this repair guide.
Nerf Zombie Strike Crossbow Plunger Replacement
1 Comment
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 72
All Time: 17,267
