Nerf Zombie Strike Crossbow Trigger Spring Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
100
All Time:
4,178
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
There are some instances when the spring which allows a person to fire a Nerf crossbow breaks. One you have opened up the Nerf crossbow you will be able to tell whether or not the spring has broken. If in fact you are dealing with a broken swing then you are in luck since it can be replaced.
    1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: step 1, image 1 of 1
      • There are 19 1.0 cm screws in total.
      Ask FixBot
    2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 2, image 1 of 1
      • Separate each part of the Nerf crossbow.
      Ask FixBot
    3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 3, image 1 of 1
      • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
      Ask FixBot
    4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 4, image 1 of 1
      • Take the broken spring off of the trigger.
      Ask FixBot
    5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 5, image 1 of 1
      • Replace it with the new spring you bought at your local hardware store.
      Ask FixBot
    6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: step 6, image 1 of 1
      • Now that the spring has been reattached to the trigger repeat step two.
      • Finish by performing steps two and three in reverse order.
      Ask FixBot
Benjamin Bucklin
61 Reputation
3 Guides authored
1 Guide Comment
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 100
All Time: 4,178
