Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vision is Blocked
Robot travels a short distance, stops, then asks user to clear its path
Faulty Laser
Start up your robot and see if laser on top is rotating to scan the room. If laser is spinning consider using compressed air to clean the laser. If not, consider replacing the laser using Neato Botvac 80 Laser Replacement.
Blocked Path
Make sure nothing is blocking the robot, it is flat on the ground, and there are no cords tangled. If problem persists, charge the robot until the light is solid green.
Won't Charge
Robot will not hold a battery charge or turn on
Faulty Battery
If robot does not turn on or charges, leaves base, and then returns after only a few minutes consider replacing the battery using this Neato Botvac 80 Battery Replacement.
Faulty Charge Dock
Make sure the dock is plugged in and the robot fully touches the charging contacts. If no charge indicator lights up on the robot, a new charger may need to be purchased.
Device not Cleaning Efficiently
Robot seems to lose its effectiveness while cleaning
Blockage in Filter and/or Suction Region
Make sure to clean the brushes and filter as they accumulate debris after frequent usage.
Battery Calibration Required
Every once in a while, the robot needs a calibration to improve battery performance.
Botvac Not Responding
Robot does not respond to button commands, and may even not turn on
Battery Improper Seating
Make sure the battery is seated correctly. If the battery is not properly installed remove and reset it.
Software Glitch
If the robot seems to be fully charged but will not move or the LCD does not show up, there may be a problem with the software. Unfortunately Neato no longer provides software updates for the Botvac 80, although some users have had success by letting the robot's battery fully drain and charging it to full.
Keeps Getting Stuck
The robot will continually get stuck or run into doors/walls.
Dirty Robot
The robot may be dirty you can clean the sensors with a Q-Tip on the sensors to remove any dust, use an air compressor to blow out the filter and dust bin, and clean off the brushes, remove any hair from anywhere you can. Replace the brush using Neato Botvac 80 Brush Replacement.
Faulty Wheels
There may be a problem with the robot's wheels. they might be dirty and a simple cleaning might help. Other than that the wheels might be damaged and you'll need to replace them. Try replacing the wheels with Neato Botvac 80 Wheel Replacement.
Corbin Olmstead
76 Reputation
0 Guides authored
USF Tampa, Team 17-5, Blackwell Spring 2017 Member of USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Members
72 Guides authored
47 Comments
The problem I have with my Neato is, it continually gives an error message saying, “My brush is stuck, free my brush.” I have cleaned the brush three times now, it’s very clean, including the bearings. I am still getting the Free my brush error message.
Any help is welcome
shelbyclay3 - Reply Share
I have the same problem, we’re you ever able to fix it?
Jeremy Pryor - Reply Share
If you pull out the brush, you’ll see that little orange piece sticking out of the side. Pull on that to free it and make sure it spins.
https://youtu.be/fPZ7EuvsyxQ
Jordan Herring - Reply Share
My Neato keeps getting stuck on the wall. I’ve cleaned the sensor with a Q-tip and dust spray. It’s still doing the same thing. I just runs right into the first wall it encounters and says it’s stuck. What should I do? It’s only 6 months old.
Lindsay Slimski - Reply Share
Neato show put my dirt bin error when the filter is fixed and won’t run. If I remove the filter it runs properly. What could be the reason?
Karthikeyan Rajendran - Reply Share
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 36
All Time: 25,135
