Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Won't Turn On
You can't get your device to power on.
Drained or Dead Battery
Your battery is dead. Try plugging the device into a power outlet for a few minutes, then try powering it on. If the battery won't hold a charge, you may need to replace it.
For help replacing the battery, see the battery replacement guide.
Bad Display
The LCD display may be broken although the rest of the phone is still working. If this is the problem, you will most likely need to replace the screen assembly.
For help replacing the display, see the display replacement guide.
Bad Motherboard
If nothing else worked, the motherboard is most likely broken. You can try performing a hard reset by holding the power button and volume down button down for 20 seconds. If that doesn't work, you will probably have to replace it.
For help replacing the motherboard, see the motherboard replacement guide.
Bad Power Button
The rest of the phone may still work, but won't recognize input from the power button. Go ahead and replace the power button.
For help replacing the power button, see the power button replacement guide.
Device Will Not Charge
Your battery drains but will not recharge.
Charging Port Not Completely Plugged In
Everything works, but something might be in the way. Make sure there is no dirt, dust, or other debris in the way. If there is, try blowing in the port.
Broken Charging Cable
The phone still works, but the electricity can't get from the wall to your device. Try charging with a different chord.
Broken Charging Port
One of the soldered connections to the motherboard most likely has broken. If you find the broken connection you can attempt to re-solder it. Otherwise, you will have to replace the motherboard.
No Service
You can't get your device to connect to your provider's coverage.
Sim Card Not Completely Plugged In
Use a paperclip to pop out the sim card tray and re-seat the sim card before pushing it back in. Also make sure the port is clean before the put it back in. If it is dirty, gently blow on it or clean it with a soft cloth.
Device Won't Recognize Service
You may be in an area that doesn't have coverage; try moving to an area that you know has service. Airplane mode may be on; try turning that off. It also may just be a bug. Try turning the device off and on, or try a hard reset.
Sim Card Port is Damaged
The Port is damaged in a way that it will not read the sim card. Since the port is attached to the motherboard, this means you will need to replace the motherboard.
Screen is Shattered
You broke the glass of the display.
Replacement Screen
Provided nothing else is broken, you just need to replace the screen assembly.
For help replacing the screen, see the screen replacement guide.
Camera Issues
Your camera takes bad pictures, or won't take pictures at all.
Not Enough Power
Sometimes the camera won't allow itself be used if the battery doesn't have enough power. Plug your device in and try again.
Software Glitch
There may be something in the software that is preventing the camera from performing correctly. Try restarting the phone, or if that doesn't work, a hard reset.
Cables Not Connected
Open up the device and check connections. If cables are not connected, plug them back in.
For help reaching the rear camera to check connections, see the rear camera replacement guide.
Camera is Broken
Something may have broken in that last 'drop test' you put your phone through. Go ahead and replace the camera.
For help replacing the rear camera, see the rear camera replacement guide.
Author
with
Ryan Meinhardt
361 Reputation
1 Guide authored
Cal Poly, Team 4-4, Maness Spring 2015 Member of Cal Poly, Team 4-4, Maness Spring 2015
CPSU-MANESS-S15S4G4
5 Members
72 Guides authored
2 Comments
A daily devotional is a short, spiritual message that is intended to encourage and inspire the reader. These messages can come from a variety of sources, but they typically contain a biblical message or reference.<a href="https://dailydevotionalwords.com">In Touch Daily Devotions</a>
Lozer Network - Reply Share
Well it doesn't recognize a network because service stopped years ago. It's still linked(and the only) accessed to a Gmail account I seriously need reaccess to. How can I do that if it doesn't have network service
Nicole Mills - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,973
