Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Kinect doesn't turn on
The Kinect will not turn on despite all of your efforts.
Kinect isn't plugged in
Check if the Kinect is securely plugged into an outlet.
Outlet isn't working
If you plugged it in and it still won't turn on, try plugging it into a different outlet.
Power Cord is damaged
Check along the length of the power cord to see if it is damaged.
If there is damage, you can try repairing the wire for splicing the wires together which may be quite difficult. Some information about splicing the wire can found Dog chewed through Kinect USB Cable - help!
Motherboard is damaged
If the three previous steps did not solve the issue, the problem may lie in a damaged motherboard.
To replace the motherboard, you can follow this guide
Kinect doesn't follow the player
When you move to the edge of the screen, the Kinect does not rotate to follow your body.
Gears are dirty or jammed
Check the gears within the stand and test if the gears are able to rotate smoothly. If lint or dirt is stuck in between the gears, try removing with q-tips or tweezers. Do not try to remove it roughly to prevent damage to the gears.
Gears are broken
If the gears are not connected or even not compete, you may need to replace the gear system.
To replace the gear system, you can follow this guide.
Instead of replacing the motor, you would only need to follow the guide until you get to the gears.
Motor is broken
If the gears turn freely and do not look damaged, the motor may be damaged
To replace the motor, you can follow this guide.
Microphone doesn't picking up sound
No matter how loud you talk or where you speak, the microphone doesn't respond to any commands.
Re-calibration is needed
Calibration sets the audio settings depending on the room the calibration occurs. If you have moved furniture around after calibrating your Kinect, you may need to re-calibrate the Kinect.
Microphone is dead
If the microphone doesn't pick up any sound regardless of what you do, you may need to replace it entirely.
To replace the microphone, you can follow this guide.
Camera doesn't recognize the user
No matter how much you move, the Kinect does not register a user.
Lenses are dirty or smudged
If there is visible dirt/lint on the lenses, clean them off with a soft-bristled brush so that you won't scratch them. With smudges, clean with a microfiber cloth, wiping in a circular motion. If it does not remove the smudge, apply a few drops of lens cleaning solution to the cloth (NOT TO THE LENS ITSELF) and continue wiping.
Lenses are cracked or damaged
If the cameras are damaged, with either scratched lenses or completely dead cameras, they may need to be replaced.
To replace the cameras, you can follow this guide.
If only the outside lenses are cracked, you can just replace the case following this guide.
Author
with
Sean Gonzales
192 Reputation
0 Guides authored
Cal Poly, Team 14-7, Amido Spring 2015 Member of Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 84
All Time: 2,449
