Microsoft Kinect Tilt Motor Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
137
All Time:
6,285
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The tilting mechanism allows the Kinect to follow the player. It operates through a motor and several gears.
Tools
    1. Microsoft Kinect Tilt Motor Replacement, Tilt Motor: step 1, image 1 of 1
      • Pull the rubber backing off the base of the Kinect.
      • If the adhesive attaching the rubber backing and the base doesn't come off with the rubber backing, remove the adhesive as well.
      • If the adhesive comes off separately, you may some type of adhesive to reattach the rubber backing.
      Ask FixBot
    2. Microsoft Kinect Tilt Motor Replacement: step 2, image 1 of 2 Microsoft Kinect Tilt Motor Replacement: step 2, image 2 of 2
      • Unscrew the four 7mm T6 Torx screws.
      • Pull off the base to reveal the inner case.
      Ask FixBot
    3. Microsoft Kinect Tilt Motor Replacement: step 3, image 1 of 3 Microsoft Kinect Tilt Motor Replacement: step 3, image 2 of 3 Microsoft Kinect Tilt Motor Replacement: step 3, image 3 of 3
      • Unscrew the four 5mm #0 Phillip screws.
      • These screws strip easily.
      • Remove the metal plate to reveal the motor and gears.
      • Disconnect the connector to separate the plate from the Kinect.
      Ask FixBot
    4. Microsoft Kinect Tilt Motor Replacement: step 4, image 1 of 1
      • Remove the three gears on top of the motor, starting with the center gear.
      Ask FixBot
    5. Microsoft Kinect Tilt Motor Replacement: step 5, image 1 of 2 Microsoft Kinect Tilt Motor Replacement: step 5, image 2 of 2
      • Unscrew the four 5mm #00 Phillip screws.
      • Remove the motor from the plate to replace.
      Ask FixBot
9 other people completed this guide.
Daniel
395 Reputation
1 Guide authored
Cal Poly, Team 14-7, Amido Spring 2015 Member of Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 Members
72 Guides authored
2 Guide Comments
Be careful not to lose the spring & washer ! ( It’s also missing a step showing where the brass washer goes )https://www.zdnet.com/pictures/microsoft...
Bantum Works - Reply Share
So far the isn’t a mention replacement of the plastic “post” that the tilt motor and the upper sensor unit are joined at. Mine broke (that’s what happens when you get a “free Xbox 360” at a neighborhood moving sale.) I couldn’t get the base plate apart as my T5 torx bit is trashed. So, my solution?…epoxy the heck out of the post as it’s only purpose is to hold the two units of the Kinect together. So far it worked!
David C - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 137
All Time: 6,285
