Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
R/C truck battery life is short
The R/C truck seems to move slower than normal.
Batteries are not properly seated
Your batteries might not be inserted properly. Check if the batteries have been placed in the R/C truck properly in accordance with the battery replacement guide.
Batteries are almost dead
The batteries have been drained which requires you to replace the batteries with newer batteries. Follow battery replacement guide.
R/C remote range is weak
The R/C truck is unresponsive at short distances from the user
Remote batteries are low
The batteries in the remote are low on charge. Try replacing the batteries.
Antennas are damaged
The antenna on either the remote or truck is damaged. Try the remote circuit board replacement first as it is easier. Then try the truck circuit board replacement if that does not work.
R/C truck does not move
R/C truck does not respond to any inputs from the controller or moves at all.
Frequency of the R/C truck and remote are not the same
Check and make sure the R/C truck and remote are set to the same channel. The frequency switch to the remote is located on the right side. The frequency switch to the R/C truck is located underneath the R/C truck.
The batteries have been drained which requires you to replace the batteries with newer quality batteries. Follow battery replacement guide.
Remote antenna is sending a wrong signals
The steering is working but not responding as necessary. The R/C truck remote is sending mixed signals to the R/C truck. Try replacing the remote circuit board. Follow the remote circuit replacement guide.
Remote antenna works but R/C truck still does not move
The R/C truck antenna is broken or disconnected. Replace the R/C truck remote circuit board. Follow the remote circuit replacement guide.
Water damage
Replacing the remote circuit board and R/C truck antenna did not fix the problem of the R/C truck not moving correctly. You may have water damage. Try replacing the R/C truck circuit board. Follow the R/C truck circuit board replacement guide.
R/C truck moves with inputs from the controller but not in right direction
The R/C truck moves at 100 percent speed but does not respond correctly to the remote control inputs from the controller.
The batteries have been drained which requires you to replace the batteries with newer quality batteries. Follow the battery replacement guide.
R/C truck moves but does not turn
The R/C truck moves but does not turn when commanded. Check for obstructions in the front tires. If the tires are obstructed try cleaning away the debris. If this does not work, try replacing the tires by following the tire replacement guide.
Front tires are unobstructed but the front tires do not move
The front motor may be broken. Try replacing the front axle. Follow the front axle replacement guide.
Front tires move but not the rear tires
Check for obstructions in the rear tires. If the tires are obstructed try cleaning away the debris. If this does not work, try replacing the tires by following the tire replacement guide.
Rear tires are unobstructed but the rear wheels do not move
The rear motor may be broken. Try replacing the rear axle. Follow the rear axle replacement guide.
Water damage
Replacing the front and rear axle did not fix the problem of the R/C truck not moving. You may have water damage. Try replacing the R/C truck circuit board. Follow the R/C truck circuit board replacement guide.
R/C truck does not move in a straight line
Both the front and rear tires are unobstructed. Both the front and rear axles are working. But still the R/C truck does not move in a straight line.
R/C truck moves at full speed but does not move in a straight line
The R/C truck may be out of alignment. Try adjusting the front alignment switch. The switch is located under the R/C truck, between the two front tires.
kevin
889 Reputation
6 Guides authored
USF Tampa, Team 1-2, Sullivan Spring 2016 Member of USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Members
72 Guides authored
19 Comments
my rock crawler 3xl can’t move foward but the steering works and i don’t know whats wrong with it
Alundra Lowry - Reply Share
Ok so try pushing it forward with throttle wide open forward like bumpstarting a car and see if it takes off and moves
Mike - Reply Share
Oh yes turn on your remote first. When u turn on truck does the steering do a jittery thing ??
Mike - Reply Share
My wesipi won’t do anything but flash the headlights and the controller light blinks also. The Truck worked the first time and that’s it. I’ve recharged the battery pack and replaced controller batteries and still the same thing. Troubleshooting guide seems like a joke. Any ideas?
Bill - Reply Share
Reverse stopped working on my daughters 3xl. Everything else working fine. Any advice please?
Mark Stabb - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 73
All Time: 21,252
