Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Device Will Not Power On
The device will not turn on when the power button is pressed.
Check to See if Battery is Charged
The battery for this device is rechargeable. If the device is not responding, the battery life may have depleted. Try charging the device with the device's original charger.
Check if the Battery is Faulty
If the device does not turn on after attempting to charge the battery, the battery may need to be replaced. To replace the battery, refer to Magellan Roadmate 1440 Battery Replacement Guide.
Check if the Charger is Faulty
The charger for the device may be the problem instead of the device itself. If the charger is failing to recharge the battery of the device, the charger may need to be replaced.
Check if the Power Switch is Faulty
The power switch may be broken and can easily be replaced. To replace it, follow the steps in Magellan Roadmate 1440 Power Switch Replacement Guide
Device Is Not Responding
The GPS isn't responding and/or is stuck on the same display page.
Try Restarting the Device
If the screen is frozen, you may want to restart the device. Slide the power button on the GPS to turn it off, and then slide it again to turn it back on.
Device Has No Audio
No audio is coming from the GPS.
Check if the Speaker is Faulty
The speaker may be broken or damaged and therefore will need to be replaced. To replace the speaker, refer to Magellan Roadmate 1440 Speaker Replacement Guide.
Device Loses Signals
The device may lose signal depending on the location, such as going through a tunnel or a wooded area.
Restarting the device can reset the signal. Try turning on and off the device by sliding the on/off button.
Device Can't Find Address
It is possible that the GPS will not be able to identify the route.
Check to See if There is An Update
New software is often released for this device through Magellan. Go to http://support.magellangps.com/support and search for Magellan Roadmate 1440 and then navigate to update the software.
4 Comments
my roadmate 1440 has never been used and when i go to update it, i get an error that says "insufficient space". i find that hard to believe that the first ever update wont fit on a brand new never used device
iamhammanu - Reply Share
I'm getting the same message. Did you ever find a workaround?
Warren Dunbar - Reply Share
Same here. No answer though.
Anthony - Reply Share
How can I factory rest the Magellan RoadMate 1440 GPS?
Iad Elmassalemah - Reply Share
