Magellan RoadMate 1440 Power Switch Replacement
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: step 1, image 1 of 1
    • Place the GPS with the screen facing down.
    Ask FixBot
  2. Magellan RoadMate 1440 Power Switch Replacement: step 2, image 1 of 2 Magellan RoadMate 1440 Power Switch Replacement: step 2, image 2 of 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
    Ask FixBot
  3. Magellan RoadMate 1440 Power Switch Replacement: step 3, image 1 of 2 Magellan RoadMate 1440 Power Switch Replacement: step 3, image 2 of 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
    Ask FixBot
  4. Magellan RoadMate 1440 Power Switch Replacement: step 4, image 1 of 3 Magellan RoadMate 1440 Power Switch Replacement: step 4, image 2 of 3 Magellan RoadMate 1440 Power Switch Replacement: step 4, image 3 of 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
    Ask FixBot
  5. Magellan RoadMate 1440 Power Switch Replacement: step 5, image 1 of 3 Magellan RoadMate 1440 Power Switch Replacement: step 5, image 2 of 3 Magellan RoadMate 1440 Power Switch Replacement: step 5, image 3 of 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
    Ask FixBot
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: step 6, image 1 of 1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
    Ask FixBot
Jeremy Johnson
201 Reputation
2 Guides authored
Clemson, Team 7-3, Benson Spring 2016 Member of Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 376
