Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Cracked Rear Cover
You have a cracked rear cover when the plastic covering starts to chip off and has holes in it. For safety purposes, you need to replace your rear cover. The following steps will help you in accomplishing rear cover replacement.
Buttons won’t work
You've tried all you could, but still can't get your buttons to work.
Broken Buttons
You have a broken button if it is cracked or does not perform the expected action when it is pressed. If this is the problem you are having, your buttons might need replacement. Follow these steps to replace your controller's buttons.
Bad Mother Board
If replacing the buttons did not resolve the button issue, the problem might be that you have a faulty motherboard. Here are some instructions for replacing the motherboard.
Worn Analog Stick Covers
You have a worn analogue stick cover if it has more friction than usual and painful to the thumb while in use. Here are instructions that will enable you to replace the analogue stick covers.
Controller won’t vibrate
Your controller does not have the vibration effect any longer.
Game settings
If your controller stops vibrating, the game setting might be the issue. Check the game setting and see if it has the vibration effect turned on. Problem not resolved? Read on!
Faulty Vibrator motor
If your controller does not work after turning ON the vibration effect in the setting menu, the problem is likely to be a faulty vibrator motor. Here are some instructions for replacing the vibrators.
Author
with
chukwubuikem
1 Reputation
0 Guides authored
USF Tampa, Team 7-2, Remmell Winter 2015 Member of USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 30
All Time: 1,902
