Mad Catz Dual Force 2 Pro Buttons Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
86
All Time:
1,169
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Please remember that these controllers are not designed to be repaired so do not be surprised if you need to be rough with it or something was not initially installed correctly. Also, the same kind of screw was used throughout the controller.
Tools
    1. Mad Catz Dual Force 2 Pro Buttons Replacement, Buttons: step 1, image 1 of 1
      • Remove the six 7 mm Phillips screws from the rear cover.
      Ask FixBot
    2. Mad Catz Dual Force 2 Pro Buttons Replacement: step 2, image 1 of 1
      • Remove the back of the controller.
      Ask FixBot
    3. Mad Catz Dual Force 2 Pro Buttons Replacement: step 3, image 1 of 1
      • Remove the two 7 mm screws on the closest circuit board.
      Ask FixBot
    4. Mad Catz Dual Force 2 Pro Buttons Replacement: step 4, image 1 of 2 Mad Catz Dual Force 2 Pro Buttons Replacement: step 4, image 2 of 2
      • Lift the closest circuit board away from the motherboard.
      • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
      Ask FixBot
    5. Mad Catz Dual Force 2 Pro Buttons Replacement: step 5, image 1 of 1
      • Remove the two 7 mm Philip screws on the larger circuit board.
      Ask FixBot
    6. Mad Catz Dual Force 2 Pro Buttons Replacement: step 6, image 1 of 2 Mad Catz Dual Force 2 Pro Buttons Replacement: step 6, image 2 of 2
      • Remove the motherboard assembly from the cover.
      Ask FixBot
    7. Mad Catz Dual Force 2 Pro Buttons Replacement: step 7, image 1 of 1
      • Lift out any of the plastic buttons you want to replace.
      Ask FixBot
Alexander Coyne
847 Reputation
5 Guides authored
USF Tampa, Team 7-2, Remmell Winter 2015 Member of USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 86
All Time: 1,169
