Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Heater Not Heating
Your device is cool to the touch, or filament does not extrude from the nozzle.
Caution: Device nozzle may be hot and may cause burns. Exercise caution when determining if device is cool.
Heater and Insulation Position is Too High
Heater issues are most commonly caused by poor location of the heater and rubber insulation. If the elements are too high up the nozzle, the tip of the nozzle would be too cool. To fix this, reposition the heater to be near the tip of the nozzle.
Air Flow
If the front cover of the print head is off, air from the environment (such as air conditioning or a breeze from an open window), may cool the nozzle. Put the cover back on the printer head, or if you have lost it, you may purchase a new one with request to M3D’s Technical Support.
Broken/Disconnected Heater Wires
Unfortunately, the heating element might just be broken, or have disconnected wires. To confirm whether the heater is broken, load the filament into the machine as usual, and open the M3D Spooler application on your computer. At the bottom of the Spooler window, you should see the temperature rising. If the temperature doesn’t rise above 50 Celcius, the heater wires may be broken or disconnected. In this case, send a photo of the broken parts to helpdesk@printm3d.com to begin the Return for Repair process.
Printer Drifting
You have problems with incorrect placement of filament by the printer.
Print Bed is Low or Uneven
Residue from previous incorrectly configured prints such as poor print bed calibration can cause the print nozzle to drift. Ensure no residue is present on print bed and properly configure the print bed offset in the software.
Friction
The friction between the movement bands and support rods is causing the nozzle to improperly print. This issue might also be caused by obstructions in the bands. Ensure nothing is blocking the tracks and carefully clean if required.
Uneven Printer Placement
The printer nozzle can become stuck moving in one direction as a result of uneven placement of the printer on a surface or friction between the movement bands. Ensure that the unit is on a level surface, and that tracks aren't blocked by debris.
Printer Not Extruding Filament
Filament is not coming out of the printer head.
Software Upgrade May Be Required
Upgrade the software by downloading it from the M3D website.
Overheating Extruder (Print Head)
The print head may be overheating, which causes the printer to have difficulty extruding material. This can then cause the filament to get pushed back up into the extruder gear. Remove wallE cover to access the extruder gear and clear the area of filament. This can also cause the fan to stop running while printing. Refer to the “fan” section.
Filament is Stuck in the Print Head
If filament is stuck in the print head, remove it. Refer to the nozzle removal guide and follow the steps.
Fan Not Working Correctly
Fan is not working while extruding.
Software Needs Updating
If the fan is on full blast and very noisy, you may need to update the software to the latest version.
Wrong M-code Was Set for the Fan
The actual M-code is not the correct one for your printer. A software upgrade will fix this problem.
Something Trapped in Blades
If the fan is working at a slower speed than usual, there may be filament or a pinched wire trapped in the blades. Remove the obstruction.
Disconnected Fan Wires
The fan wires could be disconnected. Check the wires to be sure they are connected. Make sure the fan is positioned correctly in the extruder housing. If it is too high, it will not rotate.
Broken Fan
If your fan is broken, you will need to replace it. Follow the fan replacement guide on how to replace it.
Motion Control Error
You have problems with the printer’s extrusion and motion controller chip.
Faulty Computer Connection
Attempt to reconnect the USB cable from the printer to the computer. Restart the printer and ensure LED indicator light is on. Check to see if software continues to indicate the issue.
Broken Motion Control Sensor
If the error indicating an issue with the motion control sensor reappears, follow the guide on how to replace it.
Print Not Sticking
The print is either not sticking to the print bed (build surface) or not sticking to itself.
Print not sticking to print bed
Uneven Bed Level
If the print bed is not perfectly level, the print will not adhere properly to it. Turn the 3D printer off for 5 minutes. When you turn it back on, run the bed leveling again.
More Adhesive Needed
Extra adhesive may be used to help keep the print from detaching from the print bed. Use blue painter’s tape or spray a little hairspray on the bed. You can also use a glue stick on it to help with adhesion.
Too Drafty
If the print or the bed get too cool, the print can come loose. Block any drafts that might get to the print. Tape paper or plastic over the open sides.
Print not sticking to itself
Temperature Too Low
The inks and their different materials print at different temperatures. The temperature may need to be increased to keep the print from cooling too quickly and the layers from separating.
Obstruction in Extruder Nozzle
Make sure the extruder nozzle is clean and free of debris. The layers will not fit together properly if the filament is not coming out correctly.
Printing Bed Not Level
The first layer of print must be flat and level for the successive layers to adhere properly. Make sure the extruder nozzle is close to the bed and that the bed is level.
Author
with
Yuliya Marusyk
285 Reputation
2 Guides authored
USF Tampa, Team S3-G2, Nance Fall 2017 Member of USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 6,214
